About jonny english
Essex, Chelmsford
hey guys got a problem with my speedo and rev counters when driving normal they work fine but the second you put your foot down they start jumping all over the place? also the other night as i broke for instance for a roundabout it would die and id have to restart it?? dont know if thats related but i dunno lol all i have done recently is change the thermostat, the housing and crack pipe?? problems started the same day as this work was done thanks for your help!! jon
another water leak (photos)
jonny english replied to jonny english's topic in Engine Maintenance and Problems
Cheers guys! Is this the ebay kit needed? http://cgi.ebay.co.uk/Vw-Golf-Mk3-2-8-2-9-VR6-GTi-Replacement-Thermostat-Kit-/270693531555?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f06977fa3#ht_2329wt_698 -
hi guys anyone got any ideas as to where this is leaking as i dont have a clue think it may be the thermostat?? its leaking from the pipe below the yellow plug i think thanks for your help!! http://www.4shared.com/photo/0f8X_DUy/2011-02-04_155427.html not quite sure how to do clicky and the photo is taken on my phone sorry guys!! jon
Yes you did lol its not fpr definate but he seemed interested so all good lol my vr6 is forsale on here and pistonheads but havent really had any interest lol so im gonna try and swap it woo
Hi guys anyone on here haves any knowledge of these I need a four door car now and these seem pretty good for the money I'm looking at an 02 plate 120 bhp (wow) with 60k miles in fantastic condition but just a bit worried about reliability the car has full service history but a k series engine lol any help would be much appreciated! Oh and il be swapping it for my mk3 vr6 worth it? Thanks for your help! Jonny
Hi mate I had this problem and it was the rear o/s abs sensor supremely the most common abs sensor to go! 15 quid from eurocarparts! Worth try before you post out for a pump maybe?
Hi guys i am a noob!! i cant get my rear suspension off to change the top mounts ive undone all the nuts in the boot and removed the smaller mount however i cant remove the strut and spring?!?! do i need to compress the spring to do this or does it drop out as a whole if so how do i do this!?!? thanks alot!! jon
btw im thinking of getting a decat are there any gains except noise??
cheers for the response sguys
Hi guys, What are the chances of passing an m.o.t with a de-cat?!?! cheers!! jon
HELP!! strange idle stalling problem
jonny english posted a topic in Engine Maintenance and Problems
hi guys! i have a problem that started today basically car was running beautifully since i changed the spark plugs yesterday! anyway the horn on my car doesnt work so i thought i would take the air bag panel off the steering wheel and see if i could find a dodgy connection. so i disconnected the battery took the steering wheel apart but couldnt see anything wrong so i put it all back together. started my car up an hour or so later and it initially reved to 1500rpm then dropped and stalled started it again and it did the same thing. i managed to hover the accelerator around 1000rpm and it sound -
Hi guys, This has probably been covered countless times but i was wondering if there is anyone in the chelmsford are or abouts that has vag com and could run a diagnostics on my VR6 as it has a few problems and the mot is fast approaching!! thanks alot jonny
