VR6 VDF
Everything posted by VR6 VDF
Is the toe alignment of the rear wheel adjustable?? I think ive read that the camber is fixed, but what about the toe in/out? If it is, how do you adjust it? Thanks.
Wishbone question (Ball joint stuck?)
VR6 VDF replied to nivag27's topic in Wheels, Brakes, Suspension and Steering
btw if the ball joints moved from their original position your probably gonna need to get the alignment checked! If I remember correctly, I think ball joint adjustment messes with the camber on the wheel -
Same happened to me a while back. Theres three bolts hold the ball joint onto the wishbone, they screw in from the bottom. Like mine, it looks like the bolts have worked loose and fallen out or broken off. whereever you get a new ball joint from, make sure you get 3 genuine bolts and the nut plate from VW an torque the bolts up to the correct torque. If you want it to be extra secure you can use three more nuts over the top as locking nuts. -
lol petrol prices for me aint the issue, I get circa 37mpg nearly everyday 27 mile commute with 22 miles on m-way The big issue is maintenance and parts costs, one month its road tax, another month its tyres, another month its insurance, then brake pads, then bushes, so on and so on and so on... It would really help if you knew how to do a lot of the stuff yourself? that way at least you could save on labour charges. Seriuosly, be prepared for the maintenance costs! Insurance wise Id agree with most, there really is no point using all that money on just insrurance. if you realllyyy really wan
lol that why i changed my box too, had a rattle in first! I drove on it for so long that by the time I changed it over, i think there was only 3-4 teeth left on 1st gear lol an the broken bits were rattling around in the bottom of the box. I think when I did change by box I changed the clutch aswell, but there was nothing wrong with the old one, it was just that I didnt know how long the old clutch was in there for as I had just bought the car, so thuoght better to change it out. Id say whoever is gonna change the box, ask them to inspect the clutch an see if it needs changing?
Fix 1 problem ...along comes another
VR6 VDF replied to RFC84's topic in Engine Maintenance and Problems
lol mine happened the same way too, went over one of those bloody square speed bumps! -
same happened to me lol plug sheared off, but there was also a hairline crack just near the plug so i had to get a new sump -
actually apart from the v6 4mo 2.8?
nice.... but does that mean no more 6 pot golfs??
Normally Id suggest the same to change the clutch out, but as its only been put in there 10 months ago, I really dont think theres any need? Unless when the gearbox broke it damaged the clutch? btw 2nd hand 'box is about 150
Power steering fluid leak from Rack??
VR6 VDF replied to VR6 VDF's topic in Engine Maintenance and Problems
any ideas?? -
Hi All, I changed the wishbones out on the weekend and noticed a constant drip of fluid leaking out from under the car. traced it back and the fluid seemed to be coming out of the inner tie rod boot! I squeezed the boot and more and more just kept pouring out. Im assuming that a seal broke in the steering rack and fluid is leaking down from it into the boot and out?? is that correct/possible? its also just leaking from the n/s boot and not the drivers side. also about fixes for this, is it new rack time, or are there seals that can jus be replaced? Thanks.
What is the process for fitting a new Gearbox mount?
VR6 VDF replied to morpheous1970's topic in Transmission
Easy peasy. Done the gearbox mount a while ago and done the front mount today. link: http://blackforestindustries.com/FSitems/instructions/mk3motormountinstructions.jpeg -
yea tyres are fine. but off topic sorry, how do I see my real speed via my tomtom? havnt figured it out yet...?!
LOLLL I read this on a forum a few years ago.... proper quality!!
I got the car aligned about two weeks ago with a printout so I doubt thats the problem but Hhhmm the wishbone bushes could be very true... While changing the ball joints/track rods etc I did notice the wishbone bushes were slightly ripped but I didnt want to do them at the time cos I couldnt be arsed to remove the sump to the get the bolt out. Im planning on doing that at my next oil change though so Ill see how it goes.
has anyone seen this vr6 on autotrader whooo nice
VR6 VDF replied to VR6MANN's topic in General Chat
woman owner?? (no offence just the colour! ) The pinkish interior is just nasty imo... -
Thanks Finny, I replaced the ball joints and track rod ends a few weeks ago and since then the steering has stopped wandering around so much. Before it was all over the show and would twitch and turn all the time, but it stays solid, except for when I accelerate. Ill have another look at the underside components etc and see if I can notice anything odd. If not Ill have to book it in somewhere. Thanks again.
Hi Guys, my cars recently developed this problem whereby the steering wanders away from where the wheels are pointing lol! Ok ive read the threads on a worn steering rack and my cars symptoms arent really like that i.e. hard steering on one side and softer steering on the other... etc The issue with my steering only develops when I accelerate sharply i.e accelerating between 3000-7000rpm, as I accelerate, the steering wheel turns itself to the right (wierd!). Kinda like torque steer, the more torque at the wheels, the more the steering wheel turns to the right. however, while this is happening
wow great link thanks!! Ive gotta do this job in the next few days as I found out that my gearbox mount is broken, so planning to change the front mount and the gearbox at the same time. Is it still ok to drive the car for a while until the weather beomces better??
If you want a 2nd hand one I have one in the garage and im coming to east london tomorrow could give you one? £10?
Yep MT-90 is some amazing stuff! really helped the gear changes on mine
