roodey
Everything posted by roodey
  1. Yeah mine starts from cold and also if u leave it 15 mins the engine turns over 4-5 times with the help of some pedal.....ive cleaned the idle contol valve out and still no change so i have to do the relay next and finally the fuel filter will keep u posted
  2. Iv done the temp sender switch and no change, im thinkin as above it could be the idle control valve i will try and see if i can clean it not sure how or where it is but will see. thanks for all the advice
  3. can someone tell me what the hell a (TB) is....??????? and im looking at alterring the throttle body to 90 degree s how do u do this??? im new to all this just for the record lol
  4. Ive changed the temp sender for the choke and seems to be the same so i will try the relay next if that fails ill try to get it plugged in.
  5. Hi everyone, My VR has had starting problem since i got this car 6 months ago, all i do is turn the key and the engine turns over like 4-5 time s then revs up 2000 rpm then back down again, almost as if the engine drops to many rpms for the engine to kick in for idle? ......Most of the time i jump in and turn the key foot to the metal and it fire s up straight away! I think it might be temp sender? as when u leave the car 1 hour u have to turn key foot to the floor and it fires up again! but if u leave it like 5 mins it will start up with just the key but still sounds like the engine drops to
