About johnym26
Greece, Athens
Thx, i will try that on the weekend, hope it will solve the problems.
I need a big hammer to engage 1st and second gear!!!!
Hi guys, the last 4 weeks i have a problem with my gear box. As the weather has changed and got colder, every morning before going to work, i can't engage any of the gears when i 'm starting it up. When the car isn't working i can engage all of them!!!!!! I have to let the car warm up about 15-20 min before i can engage the 2nd gear. After 1-2 km of driving i can then engage all of the gears with no problems at all. Any suggestions appreciated.
Then it will be a 40 min job
If you also have an AC radiator its a little bit tricky because it is mounted in front of the rad you want to replace. If not, its one and a half hour job max. Easy
how do i remove the "crack pipe"?
johnym26 replied to fritzenberg's topic in Engine Maintenance and Problems
As you pull it, just turn it left and right and it will pop out more easily. -
I have already got my money back with the discounts from gruvenparts and Vibra technics
And here is one of me. Although I doubt if I ever see anyone of you in person, as I am a little bit far away
You mean the ISV???? (Idle Stabilizaton Valve) next to the throttle body or the throttle body itself???
Hi guys i am thinking about changing my suspensions. I have right now koni sport (the yellow ones) and i was thinking to change them.What would you suggest? I want them to be comfortable as i use the car every day but also good handling. thanks in advance
What temp switch you replaced?The one on the thermostat housing? Because i had a same problem and i run twice out of battery since i realised what was going on and i just changed the temp switch on the rad and everything now works just fine
Vag-Com error please help!!!!
johnym26 replied to johnym26's topic in Engine Maintenance and Problems
Thx, i will try cleaning it on the weekend to see if the errors go away -
bump!!! noone??? -
Fuel pressure regulator, question.
Thx guys, i will go for the 4 bar. -
Hi guys, i have a OBD I '93 engine and i would like to ask how many bars is the fuel pressure regulator, because the one i have right now is 3 bar and the one i see in ETKA is 4. Which one should i go for? Thanks in advance
