b_singh
About b_singh
    london
  1. i brought mine on sat 16gb all is well so far cant fault it one bit, nice change from my blackberry - so far so good!! ps loving the sig Amazak!
  2. Thanks alot for the info guys will need to get on this weekend!! seriously need it
  3. hi all where is the best place to get a airflow meter? i have been quoted in excess of about 200 pounds for a new one, i have a obd2 AAA engine is the bay the best place to get them seen them go for around 65 pounds, Does it make a major difference between the part numbers or are they pretty much the same? I heard that vw do a trade for your old one for 65 pound is this true? thanks
  4. does any one know of the part number for a OBD2?
  5. hi i was wondering if any one knew if this would be ok for my mk3 vr6? It says vr6 conversions- but states mk2 also? http://cgi.ebay.co.uk/VW-GOLF-MK2-GTI-VR6-FRONT-REAR-UPPER-STRUT-BRACE-SET_W0QQitemZ270285270048QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item270285270048&_trksid=p3286.c0.m14&_trkparms=72%3A1683|66%3A2|65%3A12|39%3A1|240%3A1318 i have emailed the seller but not sure that il get a response quick enough thanks
  6. Most defintaley i done that the very next day and immediately felt a defference, tbh its still missing i have removed the air flow sensor and still is the same im beginning to feel that its the leads...so awaiting a 11mm set fingers crossed!!
  7. hi fella, yeah you can keep the angel eyes, it usually consists of a pair ballast and a bulb not much to it.... simple plug and play but the plastic cover needs to be drilled out to make space for the bulb.
  8. anyone have their direct contact details? thanks
  9. hi all, i have changed my fuel pump as my sensor had gone, question is that my car has lost its "poke" after the new pump was installed. I have been assured that its the correct one for my car although i have not yet matches the part numbers for the unit with the old one as i had to fit it lastnight under street lighting. I have a odb2 engine, could the pump be a possible cause? One thing that i havent done was install jubilee clips for the fuel hoses as i didnt have any at the time so temporarily cable tied them until later today when il get them, as i have been told that air could be gettin
  10. thanks for the swift reply!! really appreciate it!
  11. thanks for the swift reply!! really appreciate it!
