jabe
About jabe
    Female
    Peterborough
  1. I've bought powerflex poly bushes for the subframe. I've got it off the car. There seems to be a large washer on the top of the bush and the bar that connects the two bushes below. I can't remove either of these they seem welded to the metal tube through the bush. How do I remove these? Any tricks ? I assume they must come apart and that I reuse the washer and tube on the new bushes. Any help would be appreciated !!! Cheers Jason
  2. jabe
    Subframe needed
    I'm looking for a vr6 sub frame, with all bolts please. I'm in Peterborough so the nearer the better. Cheers
  3. It's all to do with the Abs fault I had it on mine. Replace the abs light and scan for fault codes will most probably be a sensor. Sent from my iPhone using Tapatalk
  4. I don't imagine it can be relocated well the standard one anyway. Do guys not usually switch to single race car style ones and new pedal boxes ? Cheers
  5. I had this on my Vr. Turned out to be battery needing charged. It would do exactly as you describe. Die unless I gave it revs and rev terrible. Could be other things I'm sure. Start with the easiest first ! Hope u get it sorted.
  6. Cheers Pete, I'm in a single garage and space is bloody tight. I wanted to avoid the hassle of engine out. If it needs to then ill need to bite the bullet ! Any ideas are mk3 sub frames all the same or must it be a Vr one? Cheers
  7. I hate my car. Why does it fight me so much on everything ? Is it possible to drop the subframe without removing the engine and box ? I was thinking support engine with jacks and hoist. Tie up steering rack and bobs your uncle. ! Any thoughts ? Cheers
  8. Cheers for the help. It's worse than I thought. I snapped the front mount bolt. I knew I'd done it but thought it had snapped just inside the threaded hole. Nope I've got just enough thread to stop the arm from pulling out. Any more ideas ? Cheers Jason
  9. Is this not an air con drain or something like that?
  10. Thanks Pete, Really appreciate you doing that for me. Cheers
  11. Not sure if this is the right place but here goes ! I know you are having issues sorting it out with the new site. Any ideas when I'll be back on ? Could do with access to the guides. Cheers
  12. Front arm mate, any ideas if there's a washer or plate which locks the bush in ? I've done the arm and bushes on my last one and it came out without any hassle ! Cheers
  13. I've got everything stripped down and all bolts out but the arm don't want to budge out of its mounting points. Seems to be held in place somehow. any ideas to help me out ? Cheers guys
  14. Do I need to remove the sump to get the front bolt out ? I've been told I can jack up the engine . Any ideas ? Cheers Jason
