i know this is vr6 owners club but does ne one know about tha agu? i have a missfire on cylinder 3 even if i change it with another coil pack it still misfires there is no spark on coil pack 3 what would cause this?
what is the first thing i should check. its not starting but i only went to it about 3 days ago and it atarted fine got in it this morning and all it does is turn over?::@
hi thanx for all da replies but my internet broke. so i haven replied. ne way im pretty sure its aaa i have had the plugs out and tested the but there is no spark ne where? really stuck now last thing to be done and its on the road.
i have brought a corrado with aaa engine code. i have transfered everything into my mk2 golf and it is turning over just havent got a spark do i need to get the ecu decoded?
i brought a corrado vr6 car with the aaa engine code on a coil pack i have now transferd everything out in to my mk2 golf and i have gone to turn it over it turns over fine but there is no spark. does the ecu need decoding?
if the rust isnt to bad you better of getting them blasted pattern parts never look right and you will prob never match the color so you will need to blend into your doors and mabey bonnet
prob not going to be a good match i work in a body shop and there are several different varients in the black magic your best of booking it in to a body shop and having the door you have got resprayed
the engine in them is well heavy you will prob end up really spoiling the ride if ya try to budget on your springs the is alot of weight up the front end cheap springs will be well bouncy what size wheels are you running?
