mrbeige
About mrbeige
    Cambridgeshire, but another planet according to my wife!
  1. Cheers guys. Getting there slowly.....very slowly haha
  2. They definitely sit right in the arches, don't they. Perhaps a 10mm space would do the trick. I guess I'd need different wheel blots in that case. What do you reckon?
  3. Cheers Nah, they are a Porsche colour. Kinda grey-blue
  4. Time for a small update. My mate has just upgraded his Corrado 24v VR with soime fancy new 17" Rotas and AP 4-pots, so his old wheels were going spare, and I thought it would be rude not to put them on the VR. Nice to finally get shot of the scabby standard BBS wheels and fit something a little bit bit different. Excuse the state of the car, she needs a bit of a wash.....
  5. Hey mate, has this car still got the shift light kit in it that I installed??
  6. I did wonder if you were venting to atmosphere. Is there any pipes attached to the wastgates as I didn't see any in the pics?
  7. Just read all 51 pages. Hats off, some impressive work gone into this.
  8. Not much going on, apart from another dodgy wiring issue. Front N/S ABS sensor fault on VAG-com, turned out to be a broken wire to the sensor. The insulation was intact, but the copper strands were broken. Replaced the pins in the plug and hey presto. Did that on Friday, as the MOT was on Saturday. Was pleased when if flew straight through that as well. Not even an advisory Next job is the chains. However, she's using a fair amount of oil which I suspect is tired valve stem seals. Have arranged a ABV block that has just come out of my mates Corrado (made way for a 2.8 24v). Will use that and
  9. Broken wiring for the O2 sensor, causing over/under fueling and misfire at idle and part throttle.
  10. Tis all fixed! Misfire has gone away. Dubiously short length on the wiring now though, so will fix that when the engine comes out in the next month or so
