Everything posted by scott-mk3
I remember similar comments about my cage from the misses aswell Found it wasnt too bad for folk sitting in the back however it did have a good few victims of folk hitting it. Arch work wasnt that major. The metal lip that goes back in the ay was fully cut away but they werent rolled or pulled etc. Front i had to pull out a little but i literally just pulled them with brute force and no roller lol.
Ha! cheers man, Really am gutted i sold it. Going to be a task to get one the same again i think. Im trying to get a highline but only for the colour really as i dont like the interiors. The wheels were 18's on it. Personnally i wouldnt go back to 18's. Id want to run 16 or 17" this time. It was my first time using the machine polisher on my car and just pretty much gave it a bash as at worst i would have got the bad bits sprayed if i balls'd it up.Took a bit but finally worked out and was swirl free. Really like the RC's on yours. would happily own yours any day mate
Looking for some help here. Fitted a new clutch on my corrado vr6 and now when coming up to the bite point there is a large amount of vibration. I thought it might just need bedding in however it has done over 50 miles now and no difference. I dont think it can be out of allignment as it goes into gear with no problem at all. Drives fine once in gear etc. Will heavily vibrate when coming down the gears for engine braking. Any more info needed ask away Any help appreciated Scott
Tried leeving the ignition on for 20mins then starting it but still didnt make any difference. Not even sure if there was any noises coming from the throttle body. The car hasnt been driven in a while if this may cause any problems? I took it a 20 mile drive and it started to idle better and where it should however occasionally on coming upto junctions and putting the clutch down it would stall as not knowing where to idle. Anymore help appreciated
So i cleaned the throttlebody on the vr6 iv got the now and the engine was out as i fitted a new clutch however i now have the problem of a bad idle. Iv searched about and it seems that i somehow need to reset the idle position on it to let it know its proper idle. Its obd2. The car will idle between 1k - 2k as if its hunting and then if i disconnect the tps and icv it will settle for a little while then i plug them back in and it idles where it should. However then on taking it a drive the idle on coming upto junctions dies almost fully if not stalling. Any help appreciated.
Ok so bit of a problem im looking to solve. Did my vr conversion like a year and a half ago now. For a while where i stay and not using it iv just been disconnecting the battery to stop it draining,however iv sorted this and relised i had my electric windows plugged into fusebox live and not fusebox ignition live. However on solving it from draining the battery it now seems though they are still sucking more power than should be. When i start the car with the windows plugged into the fusebox it starts but weakly,i have to hold the key maybe 5seconds cranking. sometimes idles lumpy for a few se
MFA Fuel consumption simple fix?
scott-mk3 replied to scott-mk3's topic in I.C.E, Security an Electrical
Fixed, simple purple wire from loom just needed plugged in. -
Looking for some guidance. Had my vr fitted in the car for a while now after coverting it from colour concept. Mk3 vr clocks etc. obd1. The mfa shows everything apart from the mpg which reads 99.9. Is this a simple plug not connected or something else? Got the fusebox and that out the now anyways as my battery keeps draining to trying to sort that out and though may aswell try get this done at the time time. Cheers scott
Nice one mate,had a feeling that as used to only be a tiny bit but now if a leeve it tikn over a wee puddle fo oil appears. Reckon itl be the same sensor used on a 2.0 8v? Got one sitting from my old engine.
Looking for some guidance before i set about fixing it. Got an oil leak coming from the top of my filter housing where one of the sensors goes in. The one on the right hand side(blue cable) Firstly looking to know what it is,oil pressure maybe? and secondly weither i should just replace the sensor,have to replace the whole filter housing or if i can jst take it out put some gasket sealer round it and bung it back in? Also can anyone give me the part number for the blue sensor in the thermostat housing..the one for the ecu engine temperature i think it is?? Going to buy a new genuine one rather
Gave my VR a bit of a detail
scott-mk3 replied to scott-mk3's topic in Members Rides and Event Photos
Ohhh dear.. i best get my machine polisher out!!! :-p Looks real good mate' date=' ive got various compounds ready to try out on my machine polisher, just need the time and the weather!! How long did your machine polishing take start to finish?? [/quote'] I used meguiars cleaner/polish for most of the rotary work. Started spreading it at setting 1 on my polisher then working upto around 2000rpm and back down again to finish off. After that i had speed glaze to try but never used it. Used chemical guys extreme top coat sealnt and then r222 concours wax to finish it off. Took me about 2-3 days -
Yeh defo is original paint on pretty much 90% of the car. Iv only had the bonnet and under rub strips on drivers side done due to some surface rust. Next would be to do the otherside under rub strips just due to stone chips. -
Cheers man, Paintwork is mostly all original. Only had the bonnet sprayed at the start of the year,but not happy with it,not keen on this new water based paint at all. -
Yeah iv done a bit of write up on what i did on the link on the first page...here it is again though http://www.theultimatefinish.co.uk/Competition/Entry.aspx?EntryId=422 However saying that i havent gone into it in that much detail about the sort of deswirling etc. When iv got a bit of time ill do a bit more in deep write up for on here (h) Changed the lights on the front of it now...the indicators/fogs. Have gone for some smoked ones. O yeah and have the bra on lol -
Cheers for the coments folks. Was pretty happy with the results i got. Was my first time properly rotary polishing. Lol got some competition of the triumph stag on ultimate finish aswell. -
Few weeks ago decided to fully rotary polish my VR. Pretty chuffed how it came out. Fired it up on Ultimate Finishes competition this month if any of you feel like firing in a vote,few more pictures up on their site aswell : http://www.theultimatefinish.co.uk/Competition/Entry.aspx?EntryId=422 Heres some pics from what i did though anyways. Also changed back to my standard grill on the front, lowered the back a little more and dewipered the tailgate. Here goes : Hope you like
Nice one getting back to me mate. Iv got an alpine headunit fitted. Ill try taking that out and see if i have anymore luck with it.Try and just have it so i need to turn it on each time. Funny you should say about the alarm. Befoe i did my conversion i had alarm fitted however i had it removed by an auto electrician. How did he manage to tell you that there was a high amount of discharge? Its really annoying me the problem so trying anything. Battery is new,was going to do alternator and ecu relay next. Guy would know doubt charge a fortune as im in scotland lol.
Hey Im looking to be changing the alternator in my car. It currently has a 70A one fitted but im wanting to fit a 120A one. My engine is OBD1 1994 but been put into a OBD2 1997 car. Im looking to find out if the brackets/connectors are the same to fit it to my car. If the connector is differnt i can go get another connector off a scraped vr and splice it on but just to know if it will fit. If anyone even has a picture of there 120A altenator connections thatd be great. Cheers
Got the same problem as this mate.Can leeve the car 3 days and the batery will be totally dead. Cant start it and very dull instrument lights. Also sometimes its a weak start and then the revs build up to idle.I know its defo electrical and not fueling or spark as when my battery is on charge and connected to car it starts like a dream. Just got a brand new battery and still doing same thing. Going to check alternator next but also want to uprate it anyways as iv got a 70A one but want the 120A from later cars. My car also hunts slightly when sitting at traffic lights around the 500 mark.Very
Another input for you mate, iv just turned 20 in the last week and have been running my VR from about last august. I had the 1.4, 1.8 , and 2.0 8v golfs but youll never get the same feeling of a VR. Its got to be one of these things you have to have if you like mk3s i think. You'll find youll love it so much you wont worry about the costs in the end. Although saying that the insurance you would be paying seems crazy. Im just 20 with 1 years no claims and im paying 960 a year. Thats with admiral fully comp. I travel from glasgow-edinburgh every week and find motorway driving sitting at 60-70 is
im not usually a fan of 18s on a mk3 either' date=' but this looks spot on... prob becuase the ride height is usually alot higher in most cases.... were these baught new? dont they cost a fortune? [/quote'] Cheers for the comments guys. Ano what you mean about 18s on a mk3,seen alot of folk who just slap them on. Think cos iv got the arches sorted to allow it to go as low it sits better. Yup indeed they were bought brand new. Hard to come by second hand and wanted them to be mint for show season ahead. Ha! Yeh lets say there a big dent in my wallet
