Afondo
Everything posted by Afondo
Before you go pulling out the gearbox, have you re aligned the selector? There are adjustments at the gear leaver and the selector. If they are not aligned then it wont go in gear easily if at all. Sounds to me like thats your problem. Its not a hard process but can take time to get it right. Google "VR6 shifter alignment" and you will find a how to. Based on what little info you have given I could almost bet that is the problem.
Crossmember bushes where to buy??
Afondo replied to Afondo's topic in Engine Maintenance and Problems
Im gonna get it up on the ramps and have a good look at it to try and find out exactly where its coming from. Once Ive got it identified Ill let you all know. -
Suspension is all new, every last bit of it and it did it before the new setup went on too -
Yeah Ive changed everything, top mounts & bearings, wishbone bushes, stabilizer bar bushes, engine mounts the lot!! Pretty sure thats where the noise is coming from but Im not 100%. What else could squeak and groan on the front end? -
Thanks for the links. So the subframe bushes are the same for all Mk3's then? -
The car is making some serious squeaking noises and Im sure its the subframe bushes as they are the only part that hasnt been changed! Does anybody know what the part number is and where I can get some? Ive seen some on ebay but am not sure if they are the same for all Mk3s.. Any ideas? Thanks
Its not for cost reasons that I dont want to lower the compression, would it not be just as counter productive adding a head spacer to a low boost install? For example,the kinetics stage 1 and 2 kits are both designed to run on totally standard engines and there are loads of people who do just that without any issues. I am well aware that a custom turbo setup is not a bolt on and go, no headaches involved system. Just because its a daily driver is not to say its my only car. What you have said basically reads: If you put a turbo setup on your car your going to have endless problems. I dont
So using a T3 turbo with a .82 trim will give me a well balanced setup that kicks in at 3000 rpm? Is this an ideal or is there a better (more recommended) setup? What sort of WHP could i expect to see running 9 psi? Would 32lb injectors with C2 software be the right fueling choice and would I need to add/uprate the fuel pump and or FPR? Would things be that bad without an LSD in the gearbox? Is anybody running this sort of setup with a standard box and clutch and how do you find it? BOV or recirc valve?
I guess this is a simple question, if you know the answer. I dont, thats why Im asking! I have been doing my research reading through build threads both here and on the vortex and have read Mr Bells bible but I do still have questions, so... I have a rebuilt OBD2 engine thats done near 9k over the pasty year. Block, head, all seals, pipes, pumps, radiator, chains, guides, all the sensors, engine & gearbox mounts, forged pistons and loads more. I really dont want to go to the expense of doing it all again so want to do this right!! I want a good setup and know what its going to set me back
Car Beeping at me - also car has ticking noise - HELP!
Afondo replied to ez_101's topic in Engine Maintenance and Problems
Sounds like the beep of death.. Last time I heard it, it cost me shitloads of cash. A noise I would rather never hear again EVER!!! Stop using the car untill you get it checked out. -
The beast is back! Ecu anyone?
Afondo replied to sirleeofroy's topic in Engine Maintenance and Problems
If you cant start the car with the new chp in place then the chip quite simply doesnt work! In now way does the Clifford alarm code for a spesific ECU. Interchanging WORKING chips or complete ECU units will have no effect on the cars ability to start/run based on the functions of your aftermarket alarm system. If however the new ECU has its own original transponder immobilizer and you dont have the correct key to disactivate it then the car will not run. But being OBD1 it is highly unlikly the ECU has this function so you dont have to wory about that in this case!! -
Ok, The condensor is the front radiator (the smaller thinner of the two). The sensor will be screwed in there or into one of the pipes leading to it. you can trace the pipes from the compressor. If the sensor is a two wire unit then you can unplug it and bridge the two wires to test. If it is a 3 wire unit then you will have to check the Bently manual for the test procedure. At any rate if the sensor is the culprit you will loose all the gas from the system when trying to change it. If you do decide to change the sensor yourself, dont let the gas out at high speed but slowly from the charge
Hi all, Just trying to find out the quantitys and types of the different liquids/fluids for the VR6 and put the info all in one place. So, how much and what type of: Break fluid = ? Engine oil = 5.5 lts 10/40 semi synthetic Power steering fluid = ? Engine coolant = ? Thanks...
Dont forget the system has a pressure switch, if its disconnected, faulty or the system is under filled the AC will not engage. I wouldnt reccomend bridging any more pins if you are not 100% certain what is what. If you kill a switch or sensor you will not be happy!! If your mate is an autosparky then just get him to check it. Right now its probably something small, most probably the pressure sensor. Really not worth trying to fix it if your not certain about what you are doing. I hope I dont sound like a cnut but it will be more expensive in the long run if you cook something blindly bridging
While the car is off the road for its re-build and the gearbox is already out, is there any reccomended mods or servicing that i should be thinking about undertaking? Already have a new clutch to go in. An LSD is not an option as I cant source one and probably couldnt afford one even if I could!! I did read something about replacing pins for bolts? Is this a worthwile job to undertake and ifso a little more detail would be great Ie. what pins, where are they located etc.. Finally what grade oil should be used and how many liters does it take to fill? The plan is to S/C the car in the next 6 or
Life just keeps getting better & better!! Not sure why or how, any help or info would be great. Here is the history in short. Before buying, I checked the car over with several knowledgable mechanics and all seemed good bar the lambda sensor. No leaks, compression test had good results and water/oil temps good. Week or so later bought the car and the very same day put new cables, NGK plugs, air filter. Next day find car leaking coolant from radiator and heater matrix!! At no point was the car driven or even started with low/no fluid. Replaced both radiators for new original units and the t
Yeah, looked on hat site but cant find the master cylinder and I still wouldnt know if I need any extra parts like seals etc. Anybody changed this part and have the part list to do so?
Following on from my previous thread regarding the clutch peddal problems I have been having, it seems I also need a new clutch! Having read that its common for the master cylinder to fail I thought it a good idea to go ahead and change it at the same time as the clutch. Can anybody tell me the part number for the master cylinder and any other seals/parts I will need to purchase to complete the job. Thanks Afondo
As per title really VAG.COM throws 18021 Electronic Control Module Incorrect Coding Would this be due to the previous owner having the ECU chipped? Thanks Afondo
Im having a similar problem with mine but its the same with the engine hot or cold. On occasions, if I change up a gear when giving it some stick the engine accelerates but the car doesnt speed up. One thing I do know is that the clutch doesnt allways return to its correct place and sometimes stays stuck to the floor. I am assuming this is the reason for my problem, once Ive got the clutch sorted Ill let you know if it has fixed the problem.
Ive got the sensor now so will be putting it in and if and when it dies ill buy the original. The sensor was also tested with a multimeter and was dead. Any ideas as to which sensor is the lambda?
Had the car plugged into the vag.com and it showed a faulty lambda sensor so I bought a generic Marelli replacement, got under the car to find 2 similar looking sensors in the exauhst pipe 1 before and the other after the cat. To make life more complicated they both have 4 wires, 2 white 1 black and 1 grey. Anybody know which one it is?
OK guys, Just done a search and have read the other thread a few lines down but not sure if I have the same problem so... the clutch peddal doesnt always return to its correct position, sometimes returning half way and on occasion staying stuck to the floor. When I lift the peddal to its correct resting point it works again for a short while and then starts doing the same thing again. Would this be the broken plate and re-weld that Im reading about and ifso what/where should I be looking to confirm this? If not, do you think a clutch slave rebuild would fix this problem? Thanks A rather unhapp
Thats good to hear. Thanks for the help! Olly.
I have just had a compression test done on the car and the results are as follows: The engine was turned 5 times for each cylinder. 1 - 151psi 2 - 155psi 3 - 153psi 4 - 150psi 5 - 151psi 6 - 155psi How did it do, is this good or bad news? Oh and the plugs were in good condition but black. Im told this is because the lambda doesnt work? Thanks Olly.
