huseby
About huseby
    norway
  1. problem fixed, it was some contact in the round engine connetor that was broken lol only that problem and i changed everything else before checking that, stupid me
  2. vag com test shows: 00553 mass air flow sensor 00281 engine speed sensor 01257 idle air control valve 00533 idle air control regulation 00525 oxsygen sensor (g39) no signal 00515 Camshaft Position Sensor (Hall Effect Sensor) -Short to B+ (G40) : Check CMP, if OK, replace distributor. u think all the air thing maby come from kon filter? what do you guys think i need to change if u see on my vagcom test above?
  3. kompression test : sylinder 1 : 110 psi sylinder 2 : 115 psi sylinder 3 : 110 psi sylinder 4 : 110 psi sylinder 5 : 110 psi sylinder 6: 110 psi how can i test the crank sensor if its broken?
  4. Hello. i was driving my 93 vr6 on the road carfully at maby 40-50 kmh then suddenly i began to like jump forward, my english is bad btw . i have this ticking sound on the engine. and spark plugg 2 and 3 seems to be just like new. i dont look like they are igniting, looks like its not getting fuel on those 2 sylinders, i have changed: sparkplugs, coilpack, entire ecu, sparkplugg wires, new injectors on sylinder 2-3 The car is running so bad, it got no pulling power at all. Can any one help me think of a problem that maby can couse the problem? ty
  5. thank you ok hatchback what`s the differense? isent that the same? i think i want to swap på original grill with the badgless one or swap to vento front not realy sure atm. what do you think?
  6. Here are some pics of my mk3 vr6 93 Projekt turbo vr comming up later here we go : I woud like some improve/change comments on the car. new things etc ty
  7. hello. i had the same problem with my vr, i changed coilpack, new spark plugs and new plug cables. same problem after, i took compresion test on all sylinders and at was good,, I need to change ecu on my vr, it wont give the signals to 2 injectors so it just running on 4 cylinders, sounds like the same problem to me but.
  8. Hello. i need to change the ecu in my vr the old one is broken and the car wont start/dead My currently ecu number is 021 90 6258 af, Do i need to get the exact number or does other ecu`s fit? any one have a ecu with this number ? ty
