f4rrs
About f4rrs
NW London
My oil pressure switches were changed yesterday as they were both leaking oil. The garage has i used has made a mistake and replaced both switched with two black tops. After much research i know understand that you should have one black top and one brown top. My question is the right or left switch the brown one? Many thanks in advance....... Paul
Hi, i have 95 VR6 OBD1 and have lots of problems starting my car. It turns over but can take up to 2 to 3 mins to catch. On a couple of ocassions the battery has gone flat before it has started. I have replaced the battery within the last two weeks and the car has just been serviced with new plugs and oil etc and it hasn't improved at all. Has anyone had this problem before? Your help would be appreciated
What are the trye pressures for standard 15" tyres?
f4rrs replied to f4rrs's topic in Wheels, Brakes, Suspension and Steering
Thanks for your help -
Oil Change 1st timer..advice needed
f4rrs replied to sadken's topic in Engine Maintenance and Problems
Hi, Also attempting a change on Sunday. Whats size nut is the filter housing nut? 32mm or 36mm Cheers Paul -
Any tips on how to clean a header tank
f4rrs replied to f4rrs's topic in Engine Maintenance and Problems
Its a project and just can't justify £27.00 on a new one -
I was going to try that tonite... How much did you use and how did it come out? Cheers -
Yes mate it was off the car. Ive tried the brush but just can't round all of the tank. A pal of mine has suggested caustic soda but that seems a bit too strong..... -
Hi There, I have a really dirty header tank. I have flushed it through but can't get my hand in there enough to clean it all. Has anyone tried to clean there's with any success. I've tried bleach with no effect... Any tips???/ Cheers Paul
Help please !!!!!How do you remove a drivers side wing?
f4rrs posted a topic in Bodywork and Styling
Need to remove my drivers side wing. where are the bolts to do this? -
How to change over a drivers side door.... Your help needed...
f4rrs replied to f4rrs's topic in Bodywork and Styling
Hi Guys, Just another question. The wires all seem to end up in a connector plug at the chasis side. How do these disconnect for removal? Many Thanks -
Hi guys/girls, I have a leeky sunroof seal that i need to replace as it lets in water.... Has anyone changed their seal and how easy is it to do? Thanks in advance
Hi, I have a rusty door that i would like to remove from my 3 door 95 VR6. The questions are: What needs to be removed before gaining access to the hinges? Do you need to remove the bumper and front wing? If so where are the mountings for the front bumper? Looking at the front wing the top part looks easy to remove but how do you remove the bottom bit? Many Thanks in advance Paul
Hi, My car is booked in this weekend as it needs some welding to the floorplan for its MOT. My problem is that ineed to remove the interior carpet just behind the drivers seat. There is an overlap piece of carpet in the rear footwell corner (3 door) witth a black cap which is about 2cm wide that i need to remove. How do you remove this cap without breaking it? I've tried turning it and levering it up but i must be doing someting wrong...... Your help would be greatly recieved.. Cheers Paul
Hi, Planning to change my coolent this weekend as looks like it hasn't been changed for years. Had a quick look under the bonnet and the bottom red hose looks like a real bugger to get to from underneath. Is it as hard as it looks or is there an alternative raining point that i have missed. Your tips ewill be greatly recieved Cheers Paul
