luckstar69
About luckstar69
    Milton Keynes
  1. Hi there, I managed to get a scan of the system, here are the results, I hope this maybe give you a clearer idea of whats wrong. Thanks. VAG-COM Version: Release 409.1-S Chassis Type: 1J - VW G/J/B Mk4 Scan: 01,02,03,08,16,15,17,19,22,35,46,56 ------------------------------------------------------------------------------- Address 01: Engine Controller: 022 906 032 E Component: MOTRONIC ME7.1 G V007 Coding: 00132 Shop #: WSC 31414 1 Fault Found: 17516 - Oxygen (Lambda) Sensor Heating: B2 S1: Performance too Low P1108 - 35-10 - - - Intermittent Readiness: 0000 0000 -----------------------------
  2. Hi I have a laptop, cable and Vag Com software that I can offer to people if they would like me to read their fault codes etc. I know for me personally, trying to find someone in my area with this to use was difficult. Cheers I have a V6 4Mo Had a VR6 Highline
  3. Yes mate, had a good chat with Greig about it. But can't really drive the thing at the moment as its really sticking! Can't afford to trailer it anywhere. Do you use them/work there?
  4. Hi I have a caliper thats almost stuck on my OSR disc and wondered if anyone could take a look? I've heard it may need winding back? The ABS and handbrake light won't go out at all. It's a V6 4motion 2000my, Garage say the sticky caliper has caused the Haldex ECU to break, just wanted to try the car out with the caliper working normally first. I'm happy to give some beers or cash for helping me. :-) Thank you
  5. Sounds good, thank you. Do you have their details please? I can try them, Will they post to me?
  6. Thanks how do I bypass/disconnect the Haldex? I had a horrible journey home with osr brake sticking half on and ABS and handbrake light flashing at me! Its a 2000my X reg 84k miles VW history up to2005/6 at Lookers /Liverpool VW. Other history I have is non VW. up to 2008.
  7. Thanks for replying. They used VAG_COM but they didnt give me the fault codes. I have friend who can plug me in and look them up on his laptop.
  8. Hi there, I bought a V6 4Motion on Sat and I think I bought a bit of a pig, I love the car but not the problems I have with it. On the way home it started squeaking on the o/s/r wheel. It turns out the caliper is clamping on as maybe its sticky and this over time has caused the Haldex ECU to fail. Below is a list of things my local VW specialist has recommended. The car now has ABS light on and the handbrake light on, it wont go off, I think they jammed the caliper even tighter on the disc, its really rubbing now and I'm worried its gonna mess up the disc and pad and mess up the 4wd! They sa
  9. Hi there I sold my VR6 Highline last year, saved up some pennies and yesterday bought a 3 door, Silver, V6 4Mom I love it! I just need some advice on a few bits that I'd like to repair/replace please. 1) One of the wings paintwork looks all cracked & water marked, like the lacquer is cracking (but feels smooth), I wondered if I should just buy a wing from eb@y and put it on myself, is this easy? 2) I need a seat handle lever ( its a 3 door) as I don’t have one on either seat and cant tilt seats forward! 3) I think I managed to fix the rear washer just problem yesterday after I noticed th
  10. Ok , thanks. I think the actual plastic tank on mine is leakinig.
  11. Hi all I think my tank is leaking, I am not 100% sure though, when I top the coolant up to max level, I check my driveway and the next morning its dripped a bit and after a day or 2, I'm back down to minimum level on the tank, just under the tank seal where the 2 halves are joined. There is no leak from the cap itself, its dry around this area. I can’t see where it’s leaking from but I know it’s dripping from a height, I can feel the back of the tank and it feels damp, just after I’ve topped it up and sometimes see a drip hanging from the bottom of the tank. I can’t pin point the le
