luckstar69
Everything posted by luckstar69
  1. Hi there, I managed to get a scan of the system, here are the results, I hope this maybe give you a clearer idea of whats wrong. Thanks. VAG-COM Version: Release 409.1-S Chassis Type: 1J - VW G/J/B Mk4 Scan: 01,02,03,08,16,15,17,19,22,35,46,56 ------------------------------------------------------------------------------- Address 01: Engine Controller: 022 906 032 E Component: MOTRONIC ME7.1 G V007 Coding: 00132 Shop #: WSC 31414 1 Fault Found: 17516 - Oxygen (Lambda) Sensor Heating: B2 S1: Performance too Low P1108 - 35-10 - - - Intermittent Readiness: 0000 0000 -----------------------------
  2. Hi I have a laptop, cable and Vag Com software that I can offer to people if they would like me to read their fault codes etc. I know for me personally, trying to find someone in my area with this to use was difficult. Cheers I have a V6 4Mo Had a VR6 Highline
  3. Yes mate, had a good chat with Greig about it. But can't really drive the thing at the moment as its really sticking! Can't afford to trailer it anywhere. Do you use them/work there?
  4. Hi I have a caliper thats almost stuck on my OSR disc and wondered if anyone could take a look? I've heard it may need winding back? The ABS and handbrake light won't go out at all. It's a V6 4motion 2000my, Garage say the sticky caliper has caused the Haldex ECU to break, just wanted to try the car out with the caliper working normally first. I'm happy to give some beers or cash for helping me. :-) Thank you
  5. Sounds good, thank you. Do you have their details please? I can try them, Will they post to me?
  6. Thanks how do I bypass/disconnect the Haldex? I had a horrible journey home with osr brake sticking half on and ABS and handbrake light flashing at me! Its a 2000my X reg 84k miles VW history up to2005/6 at Lookers /Liverpool VW. Other history I have is non VW. up to 2008.
  7. Thanks for replying. They used VAG_COM but they didnt give me the fault codes. I have friend who can plug me in and look them up on his laptop.
  8. Hi there, I bought a V6 4Motion on Sat and I think I bought a bit of a pig, I love the car but not the problems I have with it. On the way home it started squeaking on the o/s/r wheel. It turns out the caliper is clamping on as maybe its sticky and this over time has caused the Haldex ECU to fail. Below is a list of things my local VW specialist has recommended. The car now has ABS light on and the handbrake light on, it wont go off, I think they jammed the caliper even tighter on the disc, its really rubbing now and I'm worried its gonna mess up the disc and pad and mess up the 4wd! They sa
  9. Hi there I sold my VR6 Highline last year, saved up some pennies and yesterday bought a 3 door, Silver, V6 4Mom I love it! I just need some advice on a few bits that I'd like to repair/replace please. 1) One of the wings paintwork looks all cracked & water marked, like the lacquer is cracking (but feels smooth), I wondered if I should just buy a wing from eb@y and put it on myself, is this easy? 2) I need a seat handle lever ( its a 3 door) as I don’t have one on either seat and cant tilt seats forward! 3) I think I managed to fix the rear washer just problem yesterday after I noticed th
  10. Ok , thanks. I think the actual plastic tank on mine is leakinig.
  11. Hi all I think my tank is leaking, I am not 100% sure though, when I top the coolant up to max level, I check my driveway and the next morning its dripped a bit and after a day or 2, I'm back down to minimum level on the tank, just under the tank seal where the 2 halves are joined. There is no leak from the cap itself, its dry around this area. I can’t see where it’s leaking from but I know it’s dripping from a height, I can feel the back of the tank and it feels damp, just after I’ve topped it up and sometimes see a drip hanging from the bottom of the tank. I can’t pin point the le
  12. Cheers guys, took the fella 20 mins, he went through 2 snapped clamps trying to fit a clamp. All done now though and I gave him a tenner for some beers. Cheers
  13. Hi, this came off tonight and makes one hell of a noise!! I'd just like some advice before I take to the local exhaust garage tomorrow. Its at the font of the car, the left part is the middle section start point. Thank you
  14. Hi mate, I was told he'd need 45 minutes to an hour to do all what was needed. I'm taking it in a 4pm today and hope I come out with a car that drives straight! I'll keep you posted. I think the HawkEye stuff they use is ok... "HawkEye™ high-definition digital imaging alignment employs patented technology to offer shops the multiple benefits of precision, high-speed alignment and greater productivity, in a minimum of bay space. Measures camber, caster, toe, thrust angle, SAI, IA, Toe-Out-On-Turns†and Maximum Steering Angle†. "
  15. Thanks guys, what's the labour time on the lower ball joints, what did it cost in total?
  16. Oh cr@p :-( , I have no overirde key. I only got 1 VW key with the car and this fob thing. Perhaps I'll just save up for an alarm system and then I'll get the new fob and alarm system. I guess I'm out of options! Thanks for your help though mate. :-d
  17. Cheers mate. I'm jealous of yours, 49k ! Mines done 129k ;-( I like the TT comp wheels to, I wants some, are they 17's? I just went and checked the alarm thing, its a Serpi Star GS3-AC (Never 'erd of um!) What can I do now?
  18. Cheers guys, I'll get it booked in on Saturday for this, i'll post the results when it's done. Thank again.
  19. Hi all Last week I had numerous repairs carried out due to pulling left, vibration and droning noise. I had these replaced: 2 x rear shocks, Inner CV joint, Rear pads and discs, rear bearings, tie rod ends (191419811) engine mount rear. All 4 wheels were balanced to (some weights were way out I was told). The vibration and droning had gone BUT it still pulls left. I find myself pulling right with some force to keep the car straight, I have done the tests of driving on the other side of road and flat roads and it always pulls left. The steering wheel naturally sits at the 11 o'clock when it’
  20. Thanks AmaZak , I think now I just need to find out what sort of fob I need. I cant get the case off mine and so many ebay fobs have certain codes such as; VW ALARM FOB REMOTE + BLANK KEY + PROGRAM HL0 1JO 959 7....just researching now! Thanks for your help.
