stu76
About stu76
kent
hi. i have a golf vr6 which was lowered at the front onto 60m springs etc. i just wanted to replace them to standard, so picked up 2 front complete legs with coils from a golf. it seems strange but upon fitment all went ok, the strange thing is the rubber seal around the brass collar under the engine bay which sits ontop of the spring now has a 1 inch gap but the old lowered springs did not. has anyone got a photo they can show me on there vr6 fron tsupension under the bonnet to see if the standard spring arrangement has the 1 inch gap around the top of the strut under the brass collar/rubber
hi kevin. i am sure no leaks from sunroof/windows etc. i removed passenger side carpet and is wet, investigated further and removed the passenger dash airbag part, found water trickling down from middle and running into passenger footwell, so it must be coming from the heater matrix or hoses, as refill expansion bottle and runs inside the car passenger side only! trouble is i cant get to it to see, half stripped car so far! wanting just to see if its the heater matrix or not, but you have a big box on the left inner side right in the way. the aux belt snapped due toa siezed pulley wheel and ca
hi. i have a leak inside the car looks like its coming from the heater matrix or one of the internal pipes has split or leaking! anyone know how to get to these easily without dimantling the whole internals of the car please? water is coming into the passenger footwell soaked the carpet but cant see where its coming from due to all the innards! any help appreciated asap. thankyou.
golf vr6 front wheel issue
stu76 replied to stu76's topic in Wheels, Brakes, Suspension and Steering
hi. i may know you, may too well? who are you then? please advise! thankyou. i will replace the belt and fill with water and see the result. thanks. -
hi. yes i know that the pump will not run without a belt, i just wondered where all the water went from the expansion bottle thats all? i will fit belt and see, would it gone into heater matrix or split pipe inside or behind the dash? thanks. -
hi. you will be a handy person to know then. i just got a vr6 with the aux belt broken due to siezed tensioner! got this job first to do, all the water has gone from expansion bottle ,any ideas on this one. i will fit the belt and tensioner and fill up with water and see what happens i think first? regards -
hi. ok then i will give it a go with the steering lock off then try again, silly me! are you local then? you do repairs etc to vr6? thanks. -
hi. yes steering lock is on, does this make a difference then? thanks. located ashford. regards -
so it may be the track rod ends that need replacement then? there is hardly any movement at wobbling the front wheels at 12 and 6 but a lot more movement at 9 and 3 side to side! could it be the front hub too?thanks. -
hi. there seems to be more movement play from each wheel at front at 9 and 3, little movement at 12 and 6, if this helps, is this wheel bearing? anyone know please? thanks. -
hi m8. i spin each wheel and dont seem to make a noise! just wondered if these are prone for bushes or wear on parts ,trackrod ends etc? thanks. -
hi. i have a vw golf vr6 m reg after jacking up the fron tof the car so both road wheels are off the road on axle stands, if i get hold of either front wheel i get a slight play/movement if i hold the wheel at 12 and 6 and get a little wobble, is this wheel bearings or is this some other common fault ,bushes somewhere? as car going in for a mot soon and need to get this sorted before it goes in. any help appreciated asap. thanks to all. regards.
hi. i have a golf vr6 m plate auto. the auxiliary drive belt snapped due to the tensioner/pulley siezed, lost water from expansion bottle, not sure where its gone? car runs but overheats due to the belt snapped and not driving the water pump etc i presume. any ideas where to check for water loss? once the auxiliary drive belt is changed will it all be ok thats the question. any ideas where to get the auxiliary rive belt and the tensioner? thankyou.
hi. i am in process of buying a golf vr6 m reg auto, was told the auxiliary drive belt broke, car overheated and may have damaged heater matrix, car was picked up by the a.a, towed home by previous owner, he is saying it only needs a new tensioner and aux drive belt! is this the case, is it worth buying the car or shall i be advised to stay clear of this one? want some advise as i really like the car and wanted to do the job myself. any advise appreciated asap. thankyou.
hi. how do you put a car for sale on this forum and add photos to it please? thanks stu
