Euro
About Euro
Hong Kong
i have some pictures onto the Supercharge kit, however I don't know know to insert them. You may contact me by E-mail, then I directly show you through my mobile. Thank you. Euro
I have a newer model V3 supercharger full kit for sale. Very new condition ! My e-mail R28golf@netvigator.com
It is really a very low mileage supercharger kit, price is negotiable. I won't read this forum everyday, you may directly send your message to my e-mail box : R28golf@netvigator.com
I am selling my VF supercharger full kit with everything. New model V3 Charger, Stage 2 (280hp) Just Bolt it on! **My country (Hong Kong) not allow me to use it legally !!! Just installed and tested running fast. Used less than 2000km V3 Black color charger, no scratch, like a new baby. Asking GBP2800 (plus delivery) For reference: https://www.ecstuning.com/Volkswagen-Jetta_III--VR6_12v/Engine/Supercharger/ES3841/ http://www.slstuning.de/shop/de/Kompressoren-und-Zubehoer/Kompressorkits-VR6-28-29/VR6-Kompressorkitsatz-Stufe-2.html
I am selling my VF Supercharger kit with nearly brand new condition ! This is a new model, V3 black color charger. Anyone interest!
Revs sometimes bouncing at 5k and sluggish
Euro replied to Gordo91's topic in Engine Maintenance and Problems
What was the cause of the fault? Please give us the update, thanks! -
Timing Chain replacement part numbers (1997 OBD 2)
Euro replied to VR6Nat's topic in Engine Maintenance and Problems
Hi brothers, My VR6 12V uses Double upper timing chain system, I purcahsed a new set of Timing chains kit for the coming engine build. However, I discover that there are wrong parts received: 1) Upper chain tensioner rail ( yellow color plastic 021 109 509E) is received, instead of existing one (dark brown metal 021 109 509A) 2) Upper piston tensioner with short body/ flat end (021 109 507B) is received, instead of existing one (longer body with a small tip on front end 021 109 507A) Can anyone tell me the above 2 parts are both new updated parts which may directly replace the old -
Thank you for information。 It is worth to add a tube between MAF and filter for a trial。 Euro
Hi all, Anyone got this similar issue? Euro
If the tuning chips on hand is already a software tuned without the MAF clamp (considered the 5V issue), what cause the fault code 00553? What steps I need to take without buying another software from somewhere? I don't know electronics, please help. Thanks. Euro
I tested drive again gentlely today, checked no fault code. Then applied full throttle in straight road, fuel cut again and code 00553 appear again, it proves that hard acceleration will have the problem. Will the car be locked in limb mode if the code 00553 appear? Anyone confirm me if install the MAF further away from the supercharger can be a solution? Euro
Hi brothers, If we apply full throttle & fuel cut suddenly for 0.5 second then recover, then a fault code 00553 appears. Does it mean the MAF read and sent more than 5 Voltes to the ECU? If the supplier says the chips is tuned without the MAF clamp, does it mean that we need to relocate the MAF (on bumper) further away from the Supercharger to solve the fule cut problem? Thanks, Euro
I face this problem, occasionally can't start when hot start..... usualy tried few times, or wait few minutes for retry, when it fires up & running strong. How to make sure?
[moved] The VR won't start on random occasions.
Euro replied to dayvery's topic in Engine Maintenance and Problems
I replaced the ignition switch (on steering column) last year, then the problem was solved. After driving for 10000km, I recently find the same problem happen to me. During the recent 50 startings in a month, the problem happen 3 times. 1st time: When the engine is hot, I stopped the car for just 1 minutes, then I failed to start again. (Engine was successfully fired up but it cut off immediately) The condition is exactly like the immobilizer is activated). After taking a rest for few minutes, I successfully started the engine, everything was fine and power was strong. 2nd time: Also engine w
