omar_magdy
About omar_magdy
    cairo
  1. thanks ,6psi daily drive then 10psi when running with others ,i am running all stock and its alot of fun ,a friend of mine who tune my megasquirt
  2. hey ,when you come again just let me know then i will take you a ride and let you see the grass
  3. hey guys again ,this is a video of my car its all stock and only 6psi 1st test and here is a full specs of my car and some pix http://www.carbon8mag.com/reader-rides/2010/08/omar-magdy---1998-vw-golf-mkiii-000752.html thanx
  4. thank u guys here in egypt grass is too much and come to see u r welcome
  5. VR6 Turbo in egypt .. i hope u enjoy engine pix comming soon
  6. I have my TPS turned on but to ecu not to MS and running map based enrichment . i am using MS fuel only but i will try to use it fuel & ignition .thnx for u all ..
  7. my ecu dont know where the throttle is ,when i diconnect the TPS i hear knocking under boost but the engine runs perfectly fine to red-line
  8. yes i am using megasquirt MAP only and TPS is not connected to megasquirt
  9. hey guys , i have golf mk3 vr6 turbo , running megasquirt fuel only till now , MAF removed , the engine runs perfectly fine to red-line .. but only up to about 80% throttle. If full throttle, the engine misfires and cutting :S i need help . thnx
  10. yeah sometimes thanx kev really nice to talk with u
  11. thanx alot kev .. will it be a daily drive ? , how much power ?
  12. hey guys .. i have a Golf 3 VR6 and i want to ask you about Turbo charging my car , its all stock and i want to know what is the maximum boost can i run with stock internals , stock compression ratio and what is the recommended Turbo for this setup note : - i am a daily driver - avilable gas octane 91 thanx
  13. lol sure we have speed humps but what can we do , sorry i cant remember how low .. i have sachs coilover .. thanx alot for ur comment
