celicatintin
Everything posted by celicatintin
  1. Hi wipers on my mk3 vr. Started a while ago after using them a while on slow speed they would judder down the screen as if the screen was dry. Regularly you could only use them on fast wipe at first then switch to slow when they would eventually stop. Go back to fast they would work then go to intermittant and they would work for a while then stop. Lately they only work on fast. Then it got worse and you have to turn on the wipers to fast and give the arms a nudge by hand to start them off. They then will work all the time but if you turn them off and wait a while they wont restart unless you
  2. 30 mpg driving gently cruising at 70-75 35 mpg
  3. Hi the list of jobs gos on and on. My wipers when you turn them off park 3" off the bottom of the screen. If i touch the wiper stalk lightly they park properly. I seem to remember you can alter this. Any ideas? Cheers Steve
  4. Hi to ecveryone i just found the culprits. 3 nuts inside the engine bay!! 1 just behind the expansion tank and 2 behiond the heat shield on the bulkhead. If you do take a dash out its not hard just methodically remove everything step by step. Oh and there are flaps in the heat shield to access the bolts dont bend the shield back. Now i know how to make the vr quicker. Strip the dash!!!!!!
  5. Hi can anyone help? I have removed all the dash etc from my mk3 vr but the heaterbox seems to be stuck still. There must be some bolts that hold it in to the bulkhead? I have looked on the forums but cant see anything please help cheers steve
