About v_dubberoon
stoke on trent
how much BPH will a standard in tank pump handle??
v_dubberoon replied to v_dubberoon's topic in Engine Tuning
cheers peeps -
hi all im in the process of fitting my nos kit, will be stating on 25 jets and working my way up to 100/150 with a progressive contoller. at what point will i need to upgrade my fuel pump ?? was thinking about a walbro 255 fittin inside my old unit. any thoughts would be great guys thanks ollie
Best location to fit my NOS injectors???
Do you happen to remember what size drill bit and tap I need? Suppose it'll be easy enough t suss out my sen, just thought I'd pick your brains while I can lol -
you legend mint is that mate thanks -
spot on cheers -
Hi all, ive done a load of reading on the topic and have a pretty good grasp of what's needed, what the engine can take etc..... Im just wondering where on the inlet to fit my injectors??? Ive got direct port crossfire injectors that in intend to tap directly into my inlet manifold. any advice on this side would be great, ive been told the closer to the throttle body as possible the better. cheers in advance all ollie
braided hoses for boxter S calipers
v_dubberoon replied to v_dubberoon's topic in Wheels, Brakes, Suspension and Steering
spot on mate, thanks -
im considering one my self, a raceland one
hi guys, my mate has a pair of 4 pots for sale off an RS4, im currently in the process of getting together the parts for the 312mm upgrade, can i use the 312mm disc and carrier with RS4 calipers?? any advice would be good regarding me fitting 4 pots, i really want some serious power up front to start me off right cheers
only my opinion but racelogic launch control seems the dogs dangleies fro shaving time off your 1/4 mile.....am sure the more knowledgeable will direct you in the best direction
wow....fucking wow.....actually had pains from laughing....amazing
am no expert but 3.68 seems a daily upgrade, 3.9 slightly more extream, 4.2 amazing for track only.....from what ive read 4.2 takes top speed down to around 125.....your choice, personally i think ill go for 3.9 when funds allow
Im in the same position fella stuck in stoke with a poor;y VR ans polo GT
suspension geometry is a fine art and never quite as simple as "as low as possible"
