fuzzwaldo
About fuzzwaldo
    Newcastle
  1. hi i am looking for a set of wheels and tyres to be used to road test my track car. ideally a set 15" 5x100 for a golf vr6 not bothered about the condition of the wheels as long as the tyres are road legal. let me know if you have anything, i'm located in newcastle cheers
  2. hi do you have the upper steering column cover thanks
  3. hi do you have the upper steering column cover thanks
  4. hi i need the top and bottom cowling (covers) for the steering column for a golf mk3 vr6. cheers
  5. Hi What are the benefits of the m4 campers over the mk3 ones Cheers
  6. Don't seem to be able to add picture using the vr6oc app. Url https://www.google.co.uk/search?q=mk3+golf+rear+brake+diagram+disc&client=ms-android-tmobile-gb&prmd=sivn&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjEqdyR7rDVAhXMDsAKHaEZAHMQ_AUICigC&biw=360&bih=560#imgrc=ktZJtMB3yOjS_M:
  7. Hi I am rebuilding new rear end of my 97 vr6. I changed the stub axles but the new arub axles do not come with the cover which goes over the stub axles bolts. The cover I need it number 5 in the diagram. Does anyone know the part number so I can get some ordered. The ones I took off have been binned. [
  8. you dont have a copy of the bentley manual that you could send me do you, i could only find one for the mk4 vr6 thanks
  9. Hi I am looking for the torque settings for the front cross member, the front sub frame, ball joints and wishbones bolts. Any help is greatly appreciated. Thanks
  10. Cheers for the advice I will give it another go this weekend. Out if interest which way did you press them in
  11. No getting the bushes through the subframe
  12. Hi After multiple attempts I don't think I am capable of installing the poly bushes in the front sub frame for my vr. Does anyone know a garage in the Newcastle area which will be able to do it for me. Thanks
  13. i have circled the screw which are missing
