spuds_own
About spuds_own
    Rotherham
  1. spuds_own
    Corrado ECU
    Mk3 rear calipers with carriers
  2. spuds_own
    Corrado ECU
    I'll have a look mate I had one in the garage. Also any joy with the calipers?
  3. That would be great mate, I'm in no massive rush. I'll drop you a message with my mobile number just let me know
  4. Hi I'm looking for a 24v v6 golf water pump pulley if anyone has got one please drop me a pm
  5. I'll just change the lot to be safe sent using telepathy
  6. I've ordered the tensioner kit from febi for my 98 vr6 obd2 as its done 158k and is starting to rattle so I started the strip down today, expecting to see some pretty major wear and all I found on the upper is this....... Is it possible the chain is also stretched and adding to the rattle? Thanks Stew sent using telepathy
  7. Just a standard Sachs I'm only running 200 Ish bhp sent using telepathy
  8. I'm in Wheatley mate I'm just about to undertake the can chains and tensioner and clutch so the car is off the road for a while sent using telepathy
  9. Sorry guys forgot to post I got it running I changed the coil pack and leads and it runs sent using telepathy
  10. I'll give it a go its really doing my head in sent using telepathy
  11. Would the engine not turn over if it was an earth fault? sent using telepathy
  12. Anyone in the Doncaster area fancy casting their eye over it? sent using telepathy
  13. Problem is I don't want to shell out on a coil pack to find out its fine sent using telepathy
