luke832
About luke832
    sheffield
  1. i linked the battery charger up, windows actually worked and up again, cd player lit up ...... so im guessing your right?
  2. ive read it could be the earthing points where are they on a vr6
  3. Hi Had a slight problem with the car rear cluster the other day, basically lighting up light a disco with all sides lighting up. Finally fixed that, and during the procedure of fixing it my stereo sub and headunit begain to play up. after all my tests on the car left/ right indicator working brakes working fine i try to stat it and it doesnt even do anything when i turn the key, the cd/player and amp doesnt even come on too. Help ? Im located in South Yorkshire if anyone could come help me sort it out or know of any aut electricians .. what should i check!
  4. After finding my auxillary water pump was unplugged i plugged it in to find out it was making a ticking noise after the car had been turned off.. can anyone tell me if its supposed to sound like this or is it buggered? Cheers Luke
  5. Okay so i plugged it in and its making a sort of ticking noise while the engine is running and when the engine is off. I noticed it when the engine was off obviously and traced it right to the aux pump. Is it supposed to make this noise ? cheers
  6. help lads need a quick answer coz someone is already making offers on this and i want it ! just wanna make sure it will fit
  7. Quick question just need a little advice before i buy it cheers dan
  8. thank you for all your help guys much appreciated Luke
  9. so shall i plug it in or leave it out? would it matter either way? my car is running rough as hell since the cold snap which is why i came across this because i was going over it with a fine tooth pick..
  10. it was actually off when i discovered it, i was like whats this free plug just doing hanging around under the plastic case, then found where it supposed to go
  11. ive tried e38 theyre just sarcastic beyond belief, its located under the HT lease plastic casing next to coil pack cheers guys
  12. na its not, i sprayed it and no cracks or electric archin, its fine, im thinkin its the maf sensor again, i got my last one from gsf i could sware it was a re conditioned one because i took it out of the packaging and it was dusty!!!! i think ive had this one for about 5k pulled the plug out to the maf sensor and the rough idle dissapeared and the car drove fine, im going to get them to swap it or i want a refund if not!!!! its a bosch and theyre apparently unreliable!
