Days Won
1
Everything posted by aminder
VR6 Samco Hoses for Sale - £100 + P&P Don't look like these have ever been used, I've had for a while in storage but no longer needed as wont fit my current engine. Located in Leicester, can also meeting around Heathrow area
Sorry sold last year.
Hi Guys. I think you can class me as a lurker I do jump on and take a read everyone and again. Having the Tapatalk app integration is a great help towards that. This is my VR Highline which I've actually sold now waiting for collection. Was a reluctant sale but didn't have the space on the driveway. This is the replacement - 3.2 DSG Audi
1996 VW GOLF MK3 VR6 Highline - £2,495 For sale 1996 MK3 Golf VR6 Highline, 112,000 miles, Purple Violet Metallic Exterior with Fully trimmed Blackberry Leather interior. MOT'ed until 19th November 2014 Location: Leicester, LE18 For more pictures visit: http://hwal.co.uk/thehighline Highline Spec MK3 Golf VR6 HighlineFull Blackberry Sports Leather Seats + Door CardsHeated Front Seats (No Bolster wear)American Walnut Wooden GearknobElectic SunroofElectric WindowsElectric Adjustable Wing MirrorsHighline Kick strips Body Pristine Body work no rust patchesNo Sill damageShaved Boot hatc
What's easiest way to free up kW coil overs?
aminder replied to Wazzoo's topic in Wheels, Brakes, Suspension and Steering
Wire brush to clean up around under the adjuster as much as you can. Prefer gt85 over wd40 or some lock shock stuff there is a wd40 version or Halfords own brand. Vice the shock up and use a big heavy hammer and keep whacking the adjuster. If no budge you can heat up the adjusters and that will definitely get them moving. Just be careful not too heat too much as you don't want to damage the shock internals. I kept touching the shock body whilst heating as soon as felt it was getting a bit too warm I stopped and commenced hammering. -
If that's worn away and unreadable you maybe best to guess the colour then go to a paint shop and check against there colour charts. What colour is it?
I'm doing the same conversion in mine at the moment pretty much at the same stage as you. Will be bolting intake manifold up tonight and plumbing up all the coolant hoses hopefully too. I'd be interested to know what the efficient placement of the MAF from the throttle body would be also - I had planned to keep OEM distance which would have thought be fine no?
You should be able to just undo the two hoses going into the heater matrix and with dash removed undo the 4 screws holding the heatermatrix in place in the complete fan unit and pull up and replace. You shouldn't need to undo any other bolts in the engine bay apart from two to remove the dash. Sounds like you trying to remove the whole heating/fan unit
Sounds like a tank, engine buggered?
aminder replied to Gadget-Master's topic in Engine Maintenance and Problems
ooohhh hope so too, theres a lot of wires there I wouldn't want to sit trouble shooting to find which one is shorting/broken -
Cheers, not sure why they came out funny first time :-) Yeah there stuff is supposed to be the best but I can't find a UK stockist.... you got any leads??
Which bit of the loom is this mate? -
I've been looking into this, I've heard a few people use this stuff below from halfords. Let us know how you get along if you do mate. As for pillars I've decided to cloth wrap them to be on safe side. http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_173967_langId_-1_categoryId_165495 http://www.vwwatercooled.org.au/f22/diy-headlining-fabric-replacement-pic-intensive-31256.html
Misfire dodgy coilpack? not really sure what it could be. how bad is it? Have you considered another test station ;-)
VR6Nat's NURBURGring pics 2010 lol
aminder replied to VR6Nat's topic in Members Rides and Event Photos
Coilpack?? I knacked mine after a sprint against a BMW on the m4 the other week. Was not firing 5 & 6. I checked by unplugging the leads one by one to see any changes to engine running. Swapped coilpack with my other VR and working a treat again. -
Very nice, Managed to get any pics of the body work after you've flat and polished it all up?
I used a damaged mk2 wing for metal and Evo-stik Hard & Fast Metal Epoxy Putty from halfords.
track day brakes?? what discs and pads
aminder replied to Tris's topic in Wheels, Brakes, Suspension and Steering
288 standard brake discs (VAG - ~£54 on trade) Mintex M1155 pads Halfords race fluid - a must as normal stuff will boil and spongy pedal feeling after couple of hard sessions -
Post your suspension / wheel setup
aminder replied to Ben Seabrook's topic in Wheels, Brakes, Suspension and Steering
Suspension - Koni Coilovers + Eibach ARB kit Wheels - 9x17's ET28 Tyres - 215/40/17' Arch work - Mild pull work going on at the moment although with slight lip roll would have worked without an issue. Issues - ************* To be completed ************* -
Inside best to use direct fusebox link get a amp meter connect one side to neg, then keep playing with other side to find a power source which clicks on when igition running
Normancoal on clubgti is selling a load of vr bits. Neuspeed pulley set maybe 268 cams (not 100% what prof)
