Nex
  • Days Won
    3
Nex last won the day on April 21 2018
Nex had the most liked content!
About Nex
    Female
    Dorset
  1. I don't know personally, however according to the internet it should work dude. I had a quick read through a number of sites. "The mk3 vr6 fuel pump can be fitted to mk3 8v and 16v the only different is the early vr6 using 4bar fuel pump and the late vr6 using 3bar fuel pump the same with 8v and 16v!" So l am guessing the same applies to the reveres
  2. Have you tested the the normal stuff i.e. make sure you're getting a spark ect..?
  3. Yeah it is if you buy a new hub too, but it is a real pain in the arse and there is a risk that you might damage the hub or the new bearing.
  4. Yup have done it a few times dude, but the easiest way is for you to take the hub off and take it to a garage from them to press out/in bearings (unless you have a press at home that is) other then that it is pretty straight forward
  5. Im sure it would do the job buddy, l just went for the R32's cos that is what l was looking for, it was OEM and l didnt have to think about the size spit between front and back and having been in a R32 l sort of knew what l was getting in terms of performance and with the others l didnt But l dont think you would be any worse off for going the Eibach route.
  6. You will be looking at about £300 ish mate, cant remember the exact cost. I ordered mine from AwesomeGTI (very good company!) this will give you an idea of cost, http://www.awesomegti.com/car/vw/golfmk4?subpart=AntiRollBars
  7. from your avatar it looks like you have a 4mo buddy, if you do, upgrade your ARB's to R32 ones (or aftermarket if you prefer) poly bush it up with a good set of coilovers, this will make the handling a whole bunch better If you can manage to find one, get your hands on a blue haldex controller. Like has been said, exhaust, decat (or gutted cat replacement) I have a cone filter, it gives no gains (or at least l don’t think so) but l like the sound lol Other then that, cams, lightend flywheel, light weight pullies. There is also a guild on here to short shift 4mo’s (l think Bungy wrot
  8. I think l just threw up a little looking at these
  9. that made me chuckle dude lol I dont use apple stuff so cant help you there
  10. I haven't myself, but l have heard good things about them. They seem to be pretty widely used by the VW crowd so cant be bad lol
  11. These guys might have what you are looking for buddy and l would guess that postage from the USA would be cheaper to you then from here http://store.034motorsport.com/products/engine-components/vw-vr6.html
  12. scuttle panel l think dude ^^^^ Yup what he said (my typing needs some speed training lol)
  13. I wont be going cos l am on a course for work
