Toast
Everything posted by Toast
  1. http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=140363436900&ssPageName=STRK:MESELX:IT try these ??
  2. it should sit around 10mm from the sump, so all in 15mm lower so it will catch more but the contact will be with the guard and not the sump spacers would be used between the gaurd and front crossmember to allow the 20mm drop of the rear mount on mk2vr conversions
  3. These will bolt up to the rear holes that are in front of the rear subframe mounts and up too the front crossmenber (needs drilling) and mounts around the front mount They have been made wider to cover the sump plug and make them stronger More holes can be made to allow oil feeds etc Feed back welcome 8-|
  4. I would need to see where the oil feed comes from/too ?
