camber can be easy to adjust on a mk3 golf vr6 if you no what your doing. step1 take off front wheel step2 look at the strut its the big thing with the spring on it step3 there are 2bolts at the bottom of the strut undo them asmall bit so it moves around step4 pull or push on the brake disc it depends on witch way your camber is leaning. inwords at the top of the wheel pull brake disc out at the top hold and do up the nuts or leaning out at the top pull brake disc towords you at the bottom hold and do up the nuts put wheel back on go for a test drive to let the springs set and recheck camber
