caretaker
About caretaker
    London
  1. So a little delayed update.. Mot was looming back in August and it sadly failed due to abs sensors needed replacing and it needed some surgery underneath! The garage agreed to due the work for lower cost if there was no rush... so after a long couple of months she was back in my hands at the beginning of Oct just missing players 2010! Just managed to get it sitting spot on now and heres a photo just before the snow.. Now its all sadly back to winter spec and the leathers are up for sale!
  2. Try and look out for a second hand vw set, usually much better fitment, if your desperate though go ecp!
  3. Thanks guys, looks like the old fashioned way is best.. just not a lot of room to work in, thought there may be some magical soloution to undo it ! you know like the old rounded off drive shaft bolt using the 12mm socket trick.. better warm up the grinder I suppose!
  4. So any one have any ideas, really need some camber shims and the damm brake caliper bolt has rusted out and the allen key is burred, any ideas on the best way to remove it? cheers James
  5. Cheers my man, there not to everyones tastes , but I do think they work so well on the 3.
  6. Little Update! Finally got round to finding another wing, so fitted them both up with a new door at the rear so the cars looking pretty rust free now! before. After! Rolled the archs a little more as needed a bit more clearance to get a little lower and popped out the inner archs so no srcubing on lock.. just need a little camber on the back, but Damm caliper bolts are rounded off at the back so thats for another weekend... Also had a complete collant over haul, new crack pipe, therm housing, rad and a nice set of fruitly coloured samcos cheers to Paul @ Regal for that.. ? ! More fun
  7. So due to the fourth tyre not holding air, I need to take it apart and go again. In the mean time I have had a set of ABTs stored up, waiting for a paint change and a set of 'safe' tyres, as they are running 185 35 17, which are like roller skates in the wet.. I thought a black spray can and a nice day on sunday, I decided to spray them up.. Managed to get a good deal on a set of toyos, from black circles, so should now get some sought of grip!
  8. Cheers guys much appreciated, your right mate I almost wrote off the mulberry interior as a viable option for the car but glad I tried it out as it really works well with the Dragon green. The actual interior was previously in my old Gti which was mystic blue, you shouldnt have any probs there mate as it looked spot on with the blue. ....regarding the arm rest its such a nice touch, it was a very lucky find!
