check your coolant mate it sounds like the head gasket has failed thats a common problem of white smoke could have blew between a water way and its going out exhaust causin the smoke and smell
hi at the back of the manifold there is a big plastic breather these blow apart with a loud bang then you loose all compression and it wont run best thing 2 do is eliminate it by joining together with a piece of pipe good luck
