Tris
About Tris
Newport isle of wight
<-- Track day at brands hatch indy
carbon wrapped roof
All back together and outside for a wash
Iv removed them when changing the engine and the label fell off. So if I turn ignition on which ever fuel comes out of that goes to the top one on the rail?
Hi 2 fuel lines from the car into the fuel rail. which one goes on what tail? thanks
so the induction side still suckes the crank case fumes. just goes throught the bottle first and uses the bottle to seperate fumes from any fluid.
thats it. where do both pipes go? 1 to rocker cover then the other? do you blank off holes on induction pipe?
Iv got the bottle catch tank? with 2 tails out of the top
Has anyone done one and taken pictures along the way or can some one explain where they fitted and plumbed the hosing? thanks
also fitted some sump baffles
New steering wheel. No other reason than it looks more track related than the momo with yellow centre band. Putting the engine back together and wrapped the manifold. Just the rad to fit, that's all connected to front end so ready to bolt on as one. Then fit the exhsust. Change brake lines and I'm done.
so I will be safe with a fully synth 70/80 and 2 litres of? thanks
iv done a search but found little what im after. spec of oil am I right in saying its 75/90 GL-4. NOT GL5 spec how much does the gearbox take? Thanks
Hmm iv just bought a lightened one off a guy on e bay. It's 7kg or 15lb took my one off and that's 6kg or 13lb
Can someone please tell me the standard 2.8 obd2 flywheel weight? Thanks
