p0u1
  • Days Won
    6
Everything posted by p0u1
  1. I would think a crank sensor or cam sensor is gone, if you can scan the car with vagcom it will tell you, where are you based? If you can't scan and need to throw parts at it I would start with making sure all the grounds are clean and tight then the crank sensor.
  2. Look for a vacuum leak, most likely the coil pack though. Where are you based?
  3. p0u1
    Tax
    Sounds like a recipe for some nice noise. I bought some eBay "special" coil overs for my vr6 many years ago .... It can go around a bend but the ride is a bit harsh, how you planning on lowering it? And you shouldn't need any wheel spacers.
  4. p0u1
    Tax
    That's a standard tax class, my 420d and vr6 is the same class. That looks nice and tidy how much is it setting you back?
  5. I agree the painter looks very good, almost looks like he can skip polishing. I'm amazed out how much tire you got to fit as well.
  6. Got new rubber that fits under the arches. Nothing special as its a set to tune on (and I'm not really bothered at this point)
  7. I must admit I was looking at such turbo you talk about but couldn't find one that would be shipped quickly. That's a eBay gt30 turbo think it cost 120 quid, I plan on seeing how long it last and I'm on the look out for a real gt35 or hx35-40 but I would also look for a eBay special ball bearing gt35. I will be sure to let you know how the Chinese turbo holds up.
  8. Started intercooler piping, need to relocate the throttle body now.
  9. Well as the title says this was my first car I bought ten years ago. I converted it to a vr6 8 years ago drove it around for 2 years then couldn't insure it. Since then I've have a few company cars and still have one now. So what I have here is a car that I don't want to get rid of even low it needs alot of tlc, so iv finally started building it up as a budget toy. I have it ruining on mega squirt 1 with 630cc injectors and a 8:1 decompression plate so it's now getting a load of budget boost. This is not going to be a expensive build
  10. This is the sort of build I wish I could justify (with the missus of course:-P) Amazing so far look forward to seeing the end results.
  11. Like I said I got a gt30 im installing, allready looking at a gt35 lol. hopefully I'll get mine done for next month, I'll upload some videos if I do. insurance starts 1 of April so I got to get it done :-P
  12. For reference http://forums.fourtitude.com/showthread.php?7074588-Longitudinal-VR6-24V-belt-tensioner-question#/topics/7074588
  13. Most likely the aux belt tensioner. I replaced the bearing in mine for 4 quid. To do this you need to remove the bearing from the pulley and to do this you will need to remove some of the lip off the hole that the bearing sits in. I used a Stanley knife it works well.
  14. Look forward to the build thread, sounds like you have a good group of friends to help out. I believe 400hp is not unreasonable on a stock block, there was someone ruining a caddy at 600hp with a stock 12v block lol Think he got a good few miles in before it went bang, if I remember correctly a piston melted. If your changing rods and pistons I think there pretty safe around 500hp, of course its normally a bad tune that kills a motor or a bad waste gate. As for welding I'm doing my own, maybe I shouldn't looking at my end results haha.
  15. I belive the 24v has a cast crank, the reason I'm staying below 400hp is because I don't want to look for clutches, gearbox's or crankshaft in the case of 24v. I'm 28 now I have a nice daily, for my toy I'm looking for affordable fun. Gt30 or gt35 if your looking for reliable fun anything bigger I hope you got money to burn. Don't want to sound old but set realistic targets and you should get there.
  16. It might be worth letting us know what the turbo has come off. If it's a diesel the general rule is look for a diesel engine twice the size of the petrol engine your planning to use it on.
  17. That's a huge turbo how much power are you looking for? People normally get gt35, I'm building mine with a gt30 turbo right now. Looking for 350-400hp my self
  18. Hi none of your photos work, you need to move away from photobucket
  19. I have heard that you can tap into the sensors and run the stand alone on top of the ECU. You may need to put a resistor on each injection output on original event to fool the original ecu. But I would strongly look to go standalone eg healtech, or chip it with a turbo map.
  20. Its not a hard swap, if you have a crain. I'm in Bedford of you need a hand but I don't have anywhere to do it.
