gwillhulk
Everything posted by gwillhulk
cheers jimmyb for your help but it there anyone ells that can, still looking for a wing. cheers.
yeah thats sound fella, but yeah ok i will give you a call then and yeah send us pictures its got to be in better condition than mine so it should be ok lol... my number is 07838138666. cheers Gwill.
would# even
I'm after a Mk3 Golf VR6 Pasanger (n/s) wing in 'mystic blue' with square indicators. I've been round most of the scrap yards around me and ebay and still not been able to find one with square if i have to i'll buy two of the oval type but it is looking like I'm having to buy new and have it sprayed. Its just time at the moment, not enough of it lol...
I've managed to get my hands on some bolt removers, well I pick them up off my mate tomorrow so hopefully after hammering these on I will be able remove them. just need to fit new bolts, does any one know the size of these by any chance so I don't have to waste another day and get these tomorrow too. need the allen bolt size, thread size and length... lol cheers...
Is that red silicone sealer around the heat exchanger cap? BODGE!!!!! I know what your saying but it aint, I bought the two new o-rings for the oil cooler and put this way i'm the over engineering type person I always like to make sure the job is done right. so I used red sealent to make sure it will never leak again< and guess what so far it aint lol....
No mate i couldn't find one at all and I not paying that much from VW so I found some plate in work, the same thickness as the floor and i've made to fit the floor pan. As the hole isn't all that big and where it is located makes it an easy fix as its right in the centre of the floor. So thats my job at the weekend lol, cutting the hole out neat...
sorted now... cheers...
My MOT is at the end of the month and I need a Drivers Front floor pan. Now i've called a few paints & pannel places close to me and there was no joy, I have also called voulkswagon (you might want to sit down for this...lol) and they said they could get one but it will be a special order from germany and it will cost £162.02, Pffft! stuff that... so, basically i'm trying to find a panel suplyer, has any one bought one or know of any place that would sell one or with my fingers crossed has one sitting on a shelf lol. I have got sheet metal so I could cut it out and make one to fit, but i'
yeah you can in a way lol... but did you replace just the crack pipe or the whole thing inc. thermosat? and did you flush the water ways out?
yeah mine doesn't have AC fella.
Dude have you got the one that leads from the thermo housing and goes up to the bottle and somewhere round the back? Mine split the other day and ive bodged it so wouldnt mind replacing it. no sorry fella, the plastic pipes i took off where buggerd and luckely enough my rubber pipes where ok after i cleaned the ends up.
Job done... Decided to replace the whole thermo (inc.all plastic's) set as when I took it all off the thermo-stat was a bit buggerd lol. anyway no leaks, crackes and all done right with no bodging...
I need the plastic pipe thats above the oil cooler and filter (center of the front end photo), that goes into the thermostate housing... cheers fella, i don't know the part number sorry.
Basicaly, yesterday I started to replace the seals on my oil cooler but come across another problem because some Garage decided to boge the repair instead of replacing it...pffft The plastic water cooling pipe has been broken at some point and the used glue and sealent tp fix it, so i'm now looking to buy a new coolent pipe. Does anyone know if VW sells these as its the only bit I need...
Can't seem to find a Haynes Bible on a Golf VR6.
gwillhulk replied to gwillhulk's topic in Engine Maintenance and Problems
cheers all, yeah i'll keep an eye out on there... but yeah deffently on the facebook petition... -
Whats this next to the oil filter in this pic?
gwillhulk replied to Lukey.'s topic in Engine Maintenance and Problems
cheers, tbh honest I suspected a trip VW might be needed as i've had this problem befor when it comes to seals and o-ring's. Is it pritty easy to do this job as I don't have a Haynes for a VR6 and come to think about I can't seem to find one. -
yeah think i'll do that then, hopefully thats the last leak to... -
mines pissing out from here but it looks like its coming from the top, thanks for answering what it is tho. If its just the seals it should be easy to fix and are they easy to get, i.e. your local auto parts shop plus could it be anythin major other than seals? cheers all...
