Flagbuggy
About Flagbuggy
    Jhb South Africa
  1. Hi Thanks that seems what I need what is the cost of that plate and can you ship to South Africa What I like about tha Plate is that If I want to go 4WD one day I just un Bolt the Plate and re-fit the Transfer case The Guy that was helping me with the 6 speed Conversion did use a VR6 Fly wheel they just made a new Ring gear to fit on the Flywheel so I am trying to get a ring gear from them but are battling That is why I have collected the Bug from them as it was a Year that nothing was done on my car and I started to do it myself I did get a Clutch Plate to fit the Spigot shaft but that
  2. Yes but there is still Ring gear and the Thrust bearing that needs to be sorted UM Do you guys sell the 6Speed ring gear aswell to fit the VR6 Flywheel ?
  3. HI Have you got links perhaps for me pls I Googled both but doing something wrong The Reason I want to convert the R32 box to 2WD is because I had a normal VR6 Transmission in my New Beetle but when I am going to refit the Motor I bought a R32 6speed trans that I want to fit on to the VR6Turbo motor in the Bug
  4. Hi Guys what needs to be done when removing the Transfer case from the R32 box and blanking the holes and making it 2WD and what CV cup needs to be used Thanks Pierre
  5. HI what are the differances between the 5 speed cables and the 6 speed cables I am doing my Beetle over that had the VRT With std vr6 box but Got a 6speed R23 that is going to be fitted now And the starter Differance?
  6. Hi thanks guys Any details for C2 When I click on the C2 of everyone I get directed to a page all I can make out C2 Motorsport UK but no contact details Help want to find out about a spacer plate When using a spacer plate do you use a head gasket either side or no head gasket just the spacer plate Pierre
  7. Holy moly Are you using a head spacer for lowering compression or what is the trick ? also fuel mix must be good then Pierre
  8. HI Guys up to what HP can I still use my std rods and when do I start using ARPRod bolts I have read some where that the std rods can handle 380Whp easy is this true?? And the 2nd question is what after market Conrods do I then buy ? Thanks in advance Pierre
  9. Hi I am a noob but have a S4 audi and a 2003 2Lturbo Passat and the new beetle Vr6T so by comparring them all The golf box will not work in the Passat as the passat box bolt to the "BACK" of the Vr motor with the CV`s going out on the sides 90Deg to the flywheel of the VR Where the Golf box the CV`s sit parrallel to the flywheel of the Vr SO Sorry mate that one I dont think will work As mentioned rather be on the lookout for the manual Passat box but only the VR one as the bolt patern on 4cyl and VR are different
  10. HI Guys Thanks for the info just after I posted this thread I worked out how the search work on the forum and started searching And as all of you have mentioned it seems the right way to go Thanks again for the advice Pierre
  11. HI I am in South Africa and want t put some Decent Pistons in my New Beetle VR6 Turbo Friend udes Arias but had a Pistn failure Does anyone here have experience with Wossner Pistns ????? Would you buy these pistons they are not cheaper than other imported Forged Pistons but aparently good Quality Any advice would be apreciated Thanks Pierre
