About donpulsar
Doncaster
I did indeed indeed post the same questions on both forums (well spotted!) as there are people who are only on one forum and not the other, so I saw no reason why I should only post on one forum. The bump's were to keep the topic on the main page so people who hadn't seen it could see it and offer a different opinion/advice that hadn't already been given. So, thankyou to everyone who read this and an even bigger thankyou to those who contributed advice. It has been invaluable. Food for thought - The club asked for people to contribute to articles, posts etc to help the club stay active and de
Bump!
Cool, cheers for the extra info. Any other info appreciated!
Ah, I take it thats with the Transporter VR & Mk4 12V VR headgaskets?
Cheers for the quick and detailed reply, that'll be a big help. Any other info appreciated!
I’ve been a member of the site for quite a while and found some very helpful info and advice, so I thought it’s about time I contributed a bit more to the site. So far my VR6 has been my daily driver since I bought it a couple of years ago (with Milltek exhaust and Piper-X panel filter), had its chains done and a new clutch around 90K and on 111K now, and the mods so far have been an LPG kit (fitted soon after I bought it & worth its weight in black gold!), a G60 3.68 final drive (amazing mod!) and a selection of air filters, finally settling with a modded airbox w/ K&N panel. I r
Dug around on the HMRC site via Google and unless Autotech can value the cams at £15 or under then anyone buying the cams will have to pay the Import VAT of 20%. ;-( So nice cams or not, at nearly £300 it turns out to be dearer than I first thought. Back to fleebay and the forums to hunt for a set!
Right then, I signed up for a normal customer account and got costs for shipping etc...here goes (based on today, 22/11 exchange rate of £1.59/$1) : Autotech 262 Cams - £136.46 ($216.97) UPS Worldwide Delivery (2-3 days) - £98.27 ($156.26) Total of - £234.73 ($373.23) So far, so good...however there's two things that need to be taken into account ; the Custom Duty & Import VAT (paid on items above a certain value, but what that is I dont know!) According to the HMRC, the Custom Duty is on average 5-9% of the actual item's value, so worst case is 9% = £12.28, and Import VAT (20%) if th
I've emailed Autotech this morning - however they're on PST so they're 8 hours behind. Hopefully I'll get a quick reply. I've asked them about the springs too so we'll see what they come back with.
Just had an email arrive from Autotech...they've got a Black Friday sale on until Monday 26th with a non-too-shabby 30% off pretty much all products...including their 262 cams that for the next 4 and a bit days are £137 for the pair! Even with shipping and import duty they're worth considering! :-d Autotech Cams! Methinks Christmas has come early :-) Steve.
Converting the VR6 to run on LPG
donpulsar replied to donpulsar's topic in Engine Maintenance and Problems
Converting the VR was one of the best things I've done - currently paying 69.9p - 71.9p/litre! Had mine done at Profess in South Wales - found them via Google - http://www.professautogas.co.uk - took a day to do the VR but its a nice part of the world so turned it into a mini holiday! They have a small army of fitters that know what they're doing, so the job was done quickly (dropped car off 8.30am) & when we returned to pick it up at around 3-4pm they were just finishing off the mapping and not had a problem since it was done. My tank is a 60 litre (full capacity 45 litres) doughnut tan -
OBD2 inlet manfiold mod and chip/remap and BBS?? All advice welcome :))
donpulsar replied to P265ajo's topic in Engine Tuning
As for the brakes, my RX2s' were fine with standard pads but for some reason I needed some spacers on the front to clear the Greenstuff Pads I put on. :-) -
The obd2 inlet hack/chop/slice weld mod, or the "Euro 2.9 mod" as it's known in the US seems to crop up on most VW forums - but from everything I've read anyone who's done this (then done a back to back test on the rollers) has found they gain pretty much 0 bhp and can lose torque ; the way the 2.8 one is shaped even though it appears restrictive does give good torque. It may differ if you did this on an OBD1 VR6 (or put a corrado one on an OBD1 Golf) - I guess if you're handy with a drill then you could buy a corrado VR inlet and re-drill it for an OBD2 throttle body (unless its off an obd2 C -
I'd be interested in one with no spouts :-)
I've got LPG on my VR & the way my system works is the gas ECU basically follows the mapping on the main ECU & you can then tweak the gas map via a cable hookup to a laptop. There's even a turbo option on my gas mapping software. So depending how your gas is setup, you may well be able to get your petrol ecu remapped & a couple of setting changed on the gas ECU & then you'll be sorted. Best to check with whoever installed the LPG but I'd say you wont have a problem! :-)
