lukavr6
Everything posted by lukavr6
if somebody is thinking about doing it, this might be of some help; http://www.shrani.si/?m/u7/42cfBL8p/23022011111.jpg http://www.shrani.si/?2W/qa/1TGsetcq/23022011113.jpg http://www.shrani.si/?I/Lz/wQ92VDY/23022011114.jpg http://www.shrani.si/?0/W0/QNFq3pB/23022011117.jpg http://www.shrani.si/?2v/vB/XHFFGQM/23022011118.jpg left is the climatronic box, the right one is the original rrado. all you need to do is to swap the plastic air went, because the passat has a lot more room in the interitor, and therefore the wents are larger. some interior electric work is needed (2 sets of cables), und
hi! will a golf' water hose fit the corrado, or are they completly different? is it possible to make some minor adjustments, for the hose to fit? this is the hose i can get for 10 euros: http://cgi.ebay.de/Kuhlerschlauch-Wasserschlauch-VW-Golf-3-VR6-1H0121101Q-/120632807630?pt=Autoteile_Zubeh%C3%B6r&hash=item1c164690ce so will it fit? thanks
if u change the mechanism, i belive you wont be able to fit the standard corrado top. so if you wanna swap, you need to change the complete set with a passat one, but the curve of the roof is different on a passat (a bit more curve than a corrado). but if you fit a glass sliding roof from a passat, you can barely notice the curve diffrence, but you need some "constructive thinking", as you need to pad the mechanism of the sliding roof, in order to work properly. i have swaped mine for the passats, but i am changinig in back to standard, as i have bought new mechanism, which should work for a
well it's the height of the tire i am concerned about. dont want my rrado to look like an offroader...
nobody runing on 215?
well in the tuv i need to pass our mot, the declared tire is 205/40/17. but i can modify the tuv, so that is no problem. 195 on a 8j rim is a bit of for me-the tire would be stretched way to much... any pics of 215/40/17 on a 8j rim?
anyone? i'm kinda in a hurry...
hi! quick question: can i put a 215/40/17 tyre on a 8*17 rim on my rrado? or should i go with 205/40/17? i get the 215's for half the price, so what do you guys think? which is the more appropriate one? cheers
don't worry mate, it took me a week to do it. i used everything from a passat, including all the sensors, wireing, etc... but the biggest trick was to fit the front panel in the dash looking stock. pics will follow, when the car is finished.
cheers guys! another problem: i have installed the climatronic sistem, the pipelines for the cooler, but i only have the passat cooler, as the previous owner of my corrado has sold it. is there a chance to fit a passat ari condition cooler on my rrado or i need to get the corrado's (i cant get it in slovenia-no used ones, no new ones)? thanks for the help
thanks guys! indeed it needs re-gassing, i just tought it might be something else. so i did it right, much less painful than i tought:D thanks for the help!
so i have now installed the ful sistem in my car, i just need some touch up on the fornt display (just some plastic reconditioner). but i have a problem with the functioning of the unit-the frickin' display keeps flashing. any ideas?
hi there! i am a proud owner of the 91' passat's climatronic sistem, which is going into my 92 vr6 corrado. i want to know if some of you fellas has already done this "upgrade", because i have difficulties installing the climatronic display into my rrados dashboard (everything else is already done). some pics of different solutions would be highly appreciated. p.s. sorry for the poor english. cheers, luka
nice rrado. hard to find them in this condition these days... too bad you will brake it for parts...
nice! so everything stays the same. upgrade of the brake fluid hoses is also a smart move i persume? do you know where to get the carriers-ebay, but i dont know how to spell brake carriers in german...
so the calipers can stay, but the carriers have to be swaped? and does anybody have zimmerman discs on? looking to buy 312's, bored, for the swap. are they ok? thanks for your help mate!
hi there! i am looking to do a brake conversion on my 92 rrado, to 312 mm discs. i've read the sticky topic, but there is a catch. i swaped my stock rrado calipers with 2 piston audi s2 calipers, redone them and with new brake pads, which i really do not want to throw away. any ideas how i check for clearance, so i make sure the caliper will fit over the disc? if not, are there any solutions, to make it fit? thanks, luka
312mm brake conversion (TT setup) write up / DIY
lukavr6 replied to Mark.'s topic in Wheels, Brakes, Suspension and Steering
will the audi s2 calipers go on the 312 discs (girling 60 calipers)? looking for an upgrade... -
hi there! in our part of europe, we have beena havung this discussion for ages: are there, or are there ot any differences in the gearboxes for the vr6 motors (gearbox codes ccm and agk)? can any of you guys help me out, cause i have 2 agk gearboxes an 3 ccm, and i have no clue which one to put on my car (2.9l rrado). tnx
so panel "sport" filters are ok? offcourse if you want something out of it, you need a bmc or cda. just wanted to kow if this filters are ok, and if you can feel any difference on the engine/power/sound, after they are installed?
Hi guys! first of all, let me say hi to all, just joined few minutes ago. now to my dilema. is it ok to use kn filter instead of a vw original filter? im not into kone filters so that is not even an option. im just looking to get a kn because ist washable, in i heard they are good. what are the pros and cons? thanks, luka
