23345matt
Everything posted by 23345matt
  1. I have the same noise but have noticed that my inner drive shaft boot has split.
  2. will do cheers, when driving seemto come from the gearbox side but could be resonating threw cab, im stumped
  3. checked that seems fine, it is doing it now accelorating and decelorating, Nothing if it is in neutral and blip the revs just when in gear and moving
  4. Just discovered that my in ddrive shaft boot on the drivers side is split. Could this be the cause of my squeel?
  5. As above I keep getting a squeal when driving. It a mk3 vr auto. It does not do it when under heavy load just when I am cruising along at constant speed. But when I lift off the accelerator pedal it goes. Any ideas guys would really hel me out.
  6. Think the lowers are tight enough just took a while to do with the old spanners as the is not alot of space to get my big mits in. Going to pop in to local exhaust specialist who make powerflow systems for them to check over. I think it's me though getting use to the different sound. Goes well though:-)
  7. Not to bad fitting but I found it a bugger to get under a tighten the lower nuts.
  8. and cut my hands to ribbons in the process
  9. Fitted raceland 6 branch yesteday but was a bitch of a job to tighten the bottom manifold nuts and it sounds like a have a little blow from the new gasket, has anyone else found this? also fitted decat but to be honest it sounds a bit tinny is this normal?
  10. Have got the 6 branches done and they look good but am having trouble getting the lower part to be tight and tidy, keep on getting lose bits on the wrap. Any advice would be welcome please guys.
  11. Just bought myself a raceland 6 branch and decat. Just wondered if there will be any gain in fitting now as I still have a standard exhaust system as I want it to keep the car looking original. Car has 2.9 inlet mani and ram air filter already and 2.9 throttle body to
  12. This guy normally has them, for about 48 quid, may be owrth emailing him and seeing if he has anymore.http://myworld.ebay.co.uk/pigeon-computing/?_trksid=p4340.l2559
  13. Can any one give me some advice on changing my anti roll bar bushes and drop links, as im replacing the front end and the car is already on stands.(also doing the wishbones/balljoints) cheers matt
  14. Thought there was only 2 clicks. Ignition on and then start.
  15. Going to clean this tomorrow but after reading the guide how do I reset this afterwards as I don't have a vag com. And dont have the Acc position on the ignition barrel. Or is this just when the ignition is turned on and not started.
  16. Is there any difference between an obd1 auto tb to a manual tb. As I'm looking at getting a ported and polished tb for mine but just wanted to check this out first.
  17. Just starting to miss it really, takes a bit of the fun away but love the kick back you get when the auto drops down
  18. I currently have a vr6 auto on a m plate with 51500 miles and love it but i miss a manual gear box should i sell it and get a manual or stick with this. Opinions welcome
  19. Have taken my coilovers off as I had a knock on the front end. Gone back to o.e spec and have still got a knocking. If I jack the car up the strut drops about 2 mm not a lot. Replaced the top mounts and bearing for new and the struts are new also. Any ideas welcome. Cheers guys
  20. Can anyone tell me what I need to do or give Me some pointers on changing the front engine mount on my be for my new solid mount. Cheers
  21. personally i dont think its stupid at all, i saw a car parked on a junction of a round about that left 3-4 inches of snow on there roof which slide down as they braked and as a result of that they had gone into the side of someone on the round about. Its about safty, i agree they dont have to give a fine and give points but if people want to be stupid and not take an extra 5 mins to sort the car out then they deserve what they get.
