the3mcc
1 Follower
About the3mcc
    Female
    louth lincolnshire
  1. il get back to you with that lol....
  2. Mine has both ac and a sunroof if that helps.. good luck with it hope you get it sorted.
  3. Ive bought a re-mapped ecu and have been told that it will not work without being re coded with my key... is this true or can i just swapped them over..?
  4. I hope you get it sorted pal.. it sounds like an aircon rad to me... im taking the aircon system outa mine.. has some one began to install aircon and given up or started taking it out and given up..?
  5. Im wanting to fit porsche brakes front and back eventually... any info would be helpful,,, Do the bolt striaght on, or are adapters required... any other problems i may need to know about when trying to fit.. or if there is a particular model of porsche brake that fits easier Thanks for any info offerd.
  6. Its Very easy.... Your abit far away for me to come help... adjusting is striaght forward.. its getting all four corners to sit at the same hieght that takes thew time...
  7. er i have dropped mine but could'nt tell you how much i slammed it then kept adjusting til it stopped rubbing to much... n If i could get a pic to load up i would put 1 on for you.. i think mine is about 600 mm from floor to underside of arch if that helps..?
  8. Nice ill rememeber to look out for the vws that should be pretty easy to see.. lol. is club campin near family camping or in the noisey bit..?
  9. Just wondered where you guys will be at bugjam i go every year n didnt realize you guys went...
  10. Hi i changed my feul tank and now my var dies when i hit the throttle.. she will tcik over but press the throttle and she just dies.. Lack of feul or to much air.. any ideas.. And ive also got a power drian wich i can not find.. has any 1 had a similar prob they can shed some light on mine with.. Thanks for any help
  11. Have you slod the supercharger...?
  12. Cool Thanks... depends how much tappits are to how tight the budget is.. lol..
  13. I was just wondering if i need to replace anything else when fitting some 268 cams. ive got the cams but while ive got the engine opened up i wondered if it was worth replacing anything else..and or if i need to upgrade anything else to get the best out of them. And finally... what kind of gains will i get from the cams coupled with a lightend fly wheel? Many thanks to some or all answers.
