marky_boy
About marky_boy
    the easten coast with marsh
  1. ah!! thanks thats that sorted. nothing important then! cheers peeps.
  2. nope nothing to connect it too. i presume you mean here (see pic). i cant see anywhere for it to connect, it runs perfectly and battery charges fine so not alternator.
  3. aircon has been deleted of engine so that makes sence. i'll go out check for the brown plug.
  4. as above. both at the front of the engine. 1st one on front right of engine four cables and brown 2nd one on left comes out of loom with alternator cables. is black with 2 cables. i think thier to do with the air con. but unsure. their is nothing for them to plug into.
  5. b&q shelf bracket (small one) will do the trick and cost pennys!
  6. got it here too but again a bit far.
  7. i know its short notice. but thursday 7th july skegness sea front carpark at 7pm. i will try my hardest to get in the carpark. darn speed humps!
  8. IT landed fine. HAd a look but what's It supposed to connect to? GOing to junk a lot of the breathers into a bath tank any way.
  9. the pipe that goes left under the air pipe. on my car it has a valve on it. i will try and get a picture up of it.
  10. camber at front is easy. undo the bottom two strut bolts push it in and re tighten. instant camber!!
