sharki
About sharki
    BRUM TOWN
  1. Need some wiring help lads. Fitted a vr to my 8v gti mk3. Everything works. Apart from the reverse lights. Now the car has been running for a year now. I did a continuity test from the reverse light switch on the gear box to the fuse and nothing. So i have managed to trace it to the rad control mod. No broken wire to there. Now i am trying to get to the fuse box area. I have looked on the a2 wiring and that says the white plug (F) connector 6&7 (black/red & black/blue) so tried to do a conti test from the connector under rad control mod to the black/red & black/blue F connector and
  2. Sounds like chain/guide slapping? Get a new kit and if i was you take the head off and get everything checked over? Also get the metal head gasket?
  3. Oh yeah sarah a VRt all the way. Have you ran proxies?
  4. Lads i need a good set of tyres for my car. I have proxies on drives side and conti on pass (yes i know) anyway pas side wheel spins sooo easy. Im thinking about getting proxies. Can anyone tell me which other make is good? Now i dont do track and my car is an anni with a vr in it. So i have the bbs rx2s on it. Need to get 215 40 16 but which letter should i get at the end of it?
  5. Did you put on coilovers? If so check the nut that holds the struts in (circle but with 2 holes in it)
  6. Davey mate. I spoke to him and he wasnt sure if his is FULLY working. How much michael?
  7. Need a fully working coilpack for my vr6 OBD2 Please pm me. ta
  8. If the rack is broken i would replace it with a good working one.
  9. Defo the spring around the crank shaft seal. Maybe it wasnt put on properly the 1st time
  10. **WANTED** Golf mk3 VR6 coilovers. Non creaking or leaking please. Please pm me ta
  11. Can anyone tell me if they used the ford coil pack and were to get one from? Or even the accel coilpack.
