seedy-steve
About seedy-steve
    gillingham kent
  1. Passenger window started going down in steps then got stuck down and yes thermal fuse is vw only and for what they are not cheap
  2. It was the motor shorting out cutting the thermal fuse in so replaced the motor put new thermal fuse in and hey presto working again
  3. Wow is all i can say that is one intense labour of love great thread
  4. Cool will have to get some pics of it up if you can i would like to see it
  5. Yes and no lol Im chaseing numbers now after haveing my two alpine type r subs in the back and manageing a healthy 132.6 db at peterborough show and upsetting a fair few people that had spent thousands i wanted to go a step further and try and have a play with a few shops with a budget home build just to see what sort of outcome i could get And i havent seen a mk3 golf done the way i have in this country so wanted to step outside the box and go different
  6. Thanks pearsy its getting there slowly Daverse no problems fella i understand work comitments and so on all that matters is it got here in the end cheers buddy
  7. Well time for an update So a fair bit has changed since i last updated Had a 6 band graphic delivered but forgot to get pic of this :S I had this delivered 30 farad yes thats right 30 farad lol And heres a couple of pics of the progress on little bits and pieces Centre console in progress which will house the 6 band graphic and two digital volt gauges How the boot is looking at the moment And a quick vid to make sure it all worked this was only set at half of what it can run All was going well today untill a dry solder decided it no longer wanted to play anymore and killed one of
  8. Hopeing for a quick shake down to make sure eveythings a1 on sunday so will post up a vid if all goes well
  9. Had a little delivery today so stuff to get on with the build And a trial fit was needed to make sure they all fit nicely
  10. well it just so happens i have a 30 farad power cap that im not using anymore that could be for sale mate If you still have this saturday when im paid then i shall have it off you
