Richiedub
About Richiedub
    South london
  1. Hey, have you tried testing the coolant switches? You may not be geting the write mixture all the time and dubs are common as muck for that! Also mine is doing the same and i put it on the scanner to check the readings and yep thats it, try that??
  2. Hey, have you tried testing the coolant switches? You may not be geting the write mixture all the time and dubs are common as muck for that! Also mine is doing the same and i put it on the scanner to check the readings and yep thats it, try that??
