About stormgreynolan
fleetwood/blackpool
Engine temp sender resistance out reading?
stormgreynolan replied to IanH26's topic in Engine Maintenance and Problems
il check auto data tommorow for u and let u know -
Engine swap won't start.
stormgreynolan replied to benh999's topic in Engine Maintenance and Problems
check all connectors if all ok get some 1 round with a decent scanner read live data whilst winding engine if no rpm readout then its crank sensor related poss all depending on if theres an immobolizer fault that can cut rpm readings/spark/injectors firing or all of them so get that checked to -
yeah u need a decent scanner that can erase emmissions related data because it will learn the values of your current maf if it is knackered your fuel trim will all be to cock the lot a ten pound scanner off ebay wont be able to reset that
im in fleetwood pal !! u can try mine and ive got a snap on scanner and vag com pop over if u want we can scan it and try it
could possible be an empty lifter run it for a bit see if it quietens down if not investigate further !! depends what kind of loud tap theres all different types of tap if u catch my drift
Supercharged VR6 (now on borbet A's)
stormgreynolan replied to ian_GTI's topic in Members Rides and Event Photos
nice motor pal ! -
Grands storm grey VR6! oshhhhh!
stormgreynolan replied to grandmstramrod's topic in Members Rides and Event Photos
177 pounds a month for insurance !!! shit the bed !!! -
pink PINK hmmmmm ???
stormgreynolan replied to stormgreynolan's topic in Wheels, Brakes, Suspension and Steering
how did u get that picture of me ha ha ha -
and it defo came out of a golf mk3 ??? the box that is prob being there fitted to rado the sharan the galaxy the golf and im uncertain but theres a merc that uses the v5 engine and the vr6 auto box but dont quote me on that i cant see the bell housing being different but the drive shaft flanges could be although they are interchangeable on most gearbox in the vag range get some numbers off the box and get google image searching
right ive got a mint set of bbs splitties the 2 piece rxii i think thats what there called noe do i spray them pink or am i just following the trend that evvveerrrryyyyy 1 seems to be doing nower days ??? also im painting my hella quads the same colour what u rekon guys
mate thats not sad at all its the pups !!!
have u checked and double checked for air leaks get it smoke tested if your local garage has the machine to do so
if ur running a mass air flow they dont do a great deal which obviously u will be doing were as on certain cars if they run map sensors they air intake temp sensor has more of a role
