About sedge
Gender
London
corollakilla reacted to a post in a topic: Vrt how to vids
My how to video would last 2 years and still not be running that's the problem. [emoji23]
sedge is attending Rolling Road Day
I'll get involved with this. Give me a date to have the golf back on the road for! The link doesnt seem to be working to register though...
Inline Filller cap for expansion bottle delete
sedge replied to Treva1990's topic in Engine Maintenance and Problems
Ah yeah that would make sense actually. Yeah i know what you mean about the fans, bmw one is massive too in terms of the thickness of it. I'm binning mine and going for a aftermarket slim line but obviously that means chopping wiring which is no good if you want to try n keep that original. -
Here's a shot of the spacer plate lined up with the cylinder head and below is one of reinz gasket..
Does the coolant system not need some kind of expansion bottle though? That would be my only concern with removing the thing completely. At least with the BMW rad it just puts the expansion bottle in a different place. -
Hi guys, So I know everyone recommends using the mk4 MLS headgasket but yesterday I went to install a Victor Reinz metal layered gasket and discovered that one of the holes to allow coolant doesn't actually properly line up with a corrado 12v head! it is only one hole that half overlaps as apposed to lining up bang on. Is this what everyone discovers and doesn't worry too much about it or is something strange going on? I have attached a photo so you can see what I mean: The steel spacer plate the gasket is offered up to in the photo lines up bang on with the cylinder head. but you can see t
Bump for a one time offer to move anything this Saturday!
KieranH reacted to a post in a topic: Car Transporter in London
daveyboy reacted to a post in a topic: Car Transporter in London
Bealieboy reacted to a post in a topic: Car Transporter in London
Hi guys, I'm moving my Golf to a new workshop next weekend (Saturday 31st Jan.) because of this I'm renting a self drive car transporter for the day. Is there anyone around the London area that needs a car or anything moving? Depending on mileage I'd only want £20-£30 to move something, not looking to make money just cover a bit of the cost of renting the transporter. The trucks got a full winch and rachet straps so no worries if theres a engine or not! Please shout up if this would be useful for anyone or people you know! Cheers, Matt
bennyk reacted to a post in a topic: mk2 vr6 Build....speachless (Not Mine)
I second the poly bush option, replaced mine not long ago and the poly bushes just slide in nicely! As for getting the old ones out, I used a saw to cut the metal sleeve running through the middle and a slice in the bush then used a big hammer and chisel to persuade them out. If you have the axel off anyway I would definately replace them!
yeah, some great ideas there too. Love the power steering bottle in the wing!
I just came across this page of a website called sr38.com and wow what a mk2 build! Apologies if youve all seen it before but its new to me and just had to share it! And if the owner uses this forum then good on you! http://www.sr83.com/bynumbuilds/?p=26
Hi guys, I have brought a walbro pump and intend on having play with fitting it tomorrow (weather permitting) I want to ask really, can I choose wether to mount it in line after the stock pump or replace the stock pump in the tank with it? The guy I brought it off was running it in tank as a replacement for the stock pump. If I can run it both ways which set up would be best?
D11PS reacted to a post in a topic: Worst job on a vr
leespiro reacted to a post in a topic: Worst job on a vr
Agree with you Luke, even better that it's quite often followed by confused looks that the noise is coming from a mk2 golf
I didn't think heater matrix was too bad but mines a mk2 golf, maybe that makes it a bit easier? Re-fitting the drivers side wishbone after putting power flex bushes in was by far the most frustrating job for me, the locating washers and spacer tube are an absolute nightmare to fit! Well worth the effort though that said.
