theflyingplumber
About theflyingplumber
    leicester
  1. cant seem to find how to upload pics ? and will go turbo after what you guys had to say
  2. thanks to all the guy who spoke to me on the club stand on sunday about turboing will get the pics of my car up asap the flying plumber
  3. thanks to all had tracking caster camber set still had the same prob so changed the rack and then re set up all sorted sticks like glue thanks again
  4. thanks guys any body know of a good set up caster camber toe the car has been lowered and stripped out only got a cage and two seats its on 16` with 205 888s
  5. hi need your help built a track car its had new wheel bearings,trackrods,ball joints anti roll bar brop links it has coil overs and fully poly bushed its been on the road for a month and now seems to have a bit of a time delay on the steering when you turn It turns ok then it turns a little more after its like the rack is moving i have spanner checked every thing tyre pressure are the same both sides i havent had it tracked as i havent foun a setting yet but its been ok for 300 miles it runs on 16" with 195 x 45 tyres any idears thanks
  6. thanks guy sorted it out earlier in the week it was a bad earth on the rear lights thanks
  7. thanks guy i am after a fibraglass one with cardon look if poss as to reduce some front end wait as the car as these are front heavey have moved the battery and wash bottle to inside the car as im going to use on the track will put some pics up asap thanks
  8. hi could anybody tell me where i can get a cardon look fibraglass bonnet from thanks the flying plumber
  9. hi im building a track car and have put on braided hoses and bleed the brakes i bought the software from gendan to use on my laptop to do all the fault codes etc and followed the system to bleed the abs system but now when i touch the brake pedal a buzzer sounds and the side light come on this did not happen until i had bleed the brakes has anybody got any idears what the problem is we have pulled through two litres of brake fluid thanks the flying plumber
