andypack
About andypack
    selkirk
  1. i know my vr6 should run on g12 coolant is there any other it can run on and howm much will i need is it 7litre or 10 litre capacity for cooling system
  2. Hi all Does anybody know if a 93 vr6 non air con has the same rad as a golf gti 16v I'm desperate as my rad popped big time last nite
  3. having a nightmare statrted the vr6 last nite and water burst everywhere seems from the bottom of the rad does anybody know if this is correct part code for rad guy has it up as marked for gti 16v but sizes seem correct , i have 93 vr6 non air con part code is 1ho 121 253d if this is not the correct does anybody know correct part code
  4. Morning all having a nightmare statrted the vr6 last nite and water burst everywhere seems from the bottom of the rad does anybody know if this is correct part code for rad guy has it up as marked for gti 16v but sizes seem correct , i have 93 vr6 non air con part code is 1ho 121 253d if this is not the correct does anybody know correct part code
  5. hi all anybody any ideas just had my pals 2.5tdi vw t4 transporter on vagcom as he has a issue when he starts it up it takes ags to fire up once fires up it runs superb no problems just takes ages to fire no faults found on vagcom anybody any ideas on what it could be
  6. im like a teenager again missus thinks im having a mid life crisis at 38 ghahhahaha but you cannot beat seeinfg all the boyracers faces in the little corsa's when u go past and your in a 19 yr old car
  7. better than my expectations , had a few golfs 8v & 16v but this is cracking , got a full milltek exhaust and ram filter on it and the noise it produces is like a symophony ohcresta after 4000 rpms, roll on sundays and nice days
  8. What are the actual fault codes you are getting on vagcom
  9. MAF and throttle body cleaned, nicely ticking over at 800 rpm and 28 mpg on a 30 mile run I'm now a happy chap, hoping for a nice day off tomorrow so I can take it for a proper blast
  10. gonna get the MAF off tonite aand clean that and throttle body, and it looks like my day off will consist of lambda sensor cheers for the replys
  11. Morning Got a 93 golf vr6 and my idle is very arratic its up and down from 200-800 fuel consumption is heavy, I have cleaned out the idle stabilastion valve, and had it on vag com and getting 2 faults One is idle stabilation fault code which says could include MAF, or fuel regulator, or throttle body and the other is Lambda Fault which also sayts could include Lambda , Maf , Fuel pump , regulator or injectors Has anybody had this problem? would a good place to start by cleaning MAF and throttle body
