Mwimab
About Mwimab
    Tamworth
  1. After swapping the engine in my mk2 I have no speedo. Ive checked the wires checked the all my fuses and the plug. Whats going on?
  2. Cheers dirtysanchez but couldnt really find much in there! Ashmk3 thats exactly what im lookin for cheers!
  3. Not that I know of. Slightly home bound at the minute without the motor!
  4. This is what I thought. But the car runs fine for 5 minutes until it has warmed up slightly so I still dont quite understand whats wrong!
  5. After reading this thread... http://forums.vwvortex.com/showthread.php?3934082 Ive noticed that when I swapped over the top part of the head, from dizzy to the coilpack, there's a magnetic pick up on the rear cam gear that I never swapped over. Is this necessary to the obd1/2 conversion? Anyone on here had any experience?
  6. After many posts about my Vr running rough when warm after swapping the block over im sure /ive just got some wires crossed somewhere! Has anybody got or can anyone point me in the direction of a wiring diagram with the plugs and colours of the wires in the engine bay. Ive searched but cant really find anything!
  7. As long as its a coil pack not a coil. I.e the black box with the 6 HT leads coming from it bolted on the side of the engine
  8. Dont think the car will make it there pal! I make it about 3 mile before it goes into gay mode and runs like crap. Cheers for the offer though!
  9. I know it goes to the header tank but it tee's off and carries on up to throttle area. Whats it do up there. Any sensors causing it not to run right with it not connected up?
  10. Exactly the same when i unplug the maf sensor. not sure about fuel pressure but like said its like a switch. I can jump in it from completely cold and its fine for 3-4 minutes and drive as quick as i like. Then like a switch it starts running like a bag of pooooo
  11. As above. What is this hear for? Does it have anything to do with the choke or mechanical running of the car? As it snapped off from here when I was doing my engine swap and now runs like crap. Would have thought this would affect it to the extent it is.
  12. Got a mk2 Vr that needs a diagnostics test/fault codes test. Although I dont think it has the port installed. Has anyone got the ability to plug it in somehow and get me a reading? Im in tamworth!
  13. Mwimab
    No speedo?
    Piss take when the cars not running right and i did have a spare everything until sunday! And now expect me to pay for the parts I need and a diagnostic test on the car, where I could have just swapped bits till I found the problem!
