B-Man
Days Won
2
B-Man last won the day on December 6 2013
B-Man had the most liked content!
About B-Man
Sutton,Surrey
£25 collection preferred due to size. Based in Sutton,Surrey. Thanks! Sent from my iPhone using Tapatalk
Lol...havnt had the time yet! All work and no play!
Marneus reacted to a post in a topic: Anyone want to help me fit my Turbo? :)
Whoohooo! Problem solved! Thanks to J4Y VR for the very helpfull info! So that means its proper test drive time! Will get a vid and some pics up soon! Sent from my iPhone using Tapatalk
Using the BMW wire so def good on that. Just spoke to J4Y VR and I think he just shook my memory and there might be some wires that I havent put back...i will check this afternoon and keep u posted! Sent from my iPhone using Tapatalk
No... Sent from my iPhone using Tapatalk
O.k ill give that a go,thanks! Could u give me like a basic route dor all the wires etc...i.e. Where from and to the wires should go when the battery is relocated just so I can double check them? Sent from my iPhone using Tapatalk
Not intermittent,when ignition is on,the guages move i.e fuel guage etc but as soon as I start her then I loose them all...all lights etc work but no "needles" if that makes sense. Sent from my iPhone using Tapatalk
Loosing all guages when car is running. Dash works perfect but just the guages that dont work when car is running. Battery was relocated to the boot so im guessing its that but ive moved the earthing points thinking it might be that but still no luck! This is what the dude used... Block up front... In boot...negative was mounted somewhere else but I moved it there to see if it will make a difference so the neg wire is a bit long as u can see Sent from my iPhone using Tapatalk
Thats cool mate,ya just around the corner. Well I just went down this route as it saved me a good few ££ but having it profesionally installed you have some piece of mind its installed o.k. This was my first attempt so hope it holds! Sent from my iPhone using Tapatalk
Hi mate. Yes she is running but still have the dash problem so havent taken her for a decent ride yet,very frustrating! Trying to aolve that issue first but not getting very far! Sent from my iPhone using Tapatalk
That Junction box o.k? Sent from my iPhone using Tapatalk
So I just checked where the earth frol battery was located and he ran it to the body just infront of the back seats...so I took it off and mounted it to where it is now in the pic to see if that will make a difference but it doesnt... Will the lenght of the negative cable affect it as it is a bit long... At the back... Block at front... Sent from my iPhone using Tapatalk
Ive got something like this up front... Sent from my iPhone using Tapatalk
Gordon...any reccomendations fo a block apart from the BMW one? Have u maybe got a pic? Also where did u mount the earth from the battery in the boot? Sent from my iPhone using Tapatalk
Well i had it done...but not sure on the junction box if honest,dont look that great. Ill take a pic later of it. I bought BMW cable anyway and that is being used. Only the pos though. Sent from my iPhone using Tapatalk
