Gordo91
About Gordo91
Prestwick
Revs sometimes bouncing at 5k and sluggish
Gordo91 replied to Gordo91's topic in Engine Maintenance and Problems
It was mapped when the supercharger was put on it years ago, i was just out in it there and it was perfect in all gears but no doubt itl change again. -
Update on this post guys it now never bounces at 5000rpm anymore it goes right through but just sluggish n hesitant at high revs , somedays it can start at 3500rpm some it can be as high as 6 , any ideas? -
Gordo91 posted a topic in Engine Maintenance and Problems
Got a supercharged vr6 that i put a new engine in a couple of weeks ago, ran sweet as a nut for a week then started being sluggish when hitting boost and not pulling as it should and now sometimes also when u hit 5000 revs its like its hitting the limiter and bouncing back, changed fuel and fuel filter but still no joy anyone had this before? -
Hi guys got a supercharged vr running around 260bhp at the moment and am about to do an engine swap and also got new lightened flywheel, atm im sure its still the standard clutch and flywheel thats in it and was going to order a stage 2 clutch from larkspeed but they said itl need to be stage 3 because stage 2 wont do , surely the stage 2 would be better than standard? Any reccomendations on what your running would be great cheers.
il have a look at that aswell but nothing was touched from when it was ok to the way it is now.
Thanks mate il look into it
Its obd2 mate. Only had it on launch and it came up with nothing
Hi guys once again on about my cr not idling, 97 supercharged vr6 idles fine untill engine is at 90 degrees then cuts out when coming to a stop , changed the plugs and the maf sensor anyone ideas?
Al sure as hell give it a try mate thanks! Not too sure theres many around my area so will prob just have to get one ordered.
Its an obd2 mate, shal need to be checked soon its so annoying!
Does it usually bring up codes for the MAF? Not had a chance to get a code reader on it yet but will be in the next few days as its driving me mad
Supercharged vr now has decided not to idle after slowing down to a stop, only does it when its right upto temperature its fine at cold or upto just before the 90 mark , any ideas?
Thanks for all the replys guys the ones that r in it just now are the ngk platinum ones only ones i could get quickly to get me back up to running the full 6 but sometimes when coming to a stop at a junction it doesnt like to idle and cuts out think it could be plug related aswell? Used to do it alot just before it went down to 5 with the same plugs in before
Anyone got any ideas which are the best plugs to use on my supercharged vr? Had a few plugs deciding to go since christmas just wondering the best make , cheers
got a z-engineering charger but need an intake pipe from maf to throttle body with the breather pipe to crankcase as mine just has a pipe coming from crankcase making a bit of a mess with oil , anyone any ideas where i could get one?
