aLaRm-888
About aLaRm-888
    Komi Republik, Syktyvkar
  1. new colour and photos all fotos here on pages 2-3-4 I would appreciate your opinion on this new color P.S. sorry for my english
  2. thanks for your opinion, what i should change in interior?
  3. may be something of this: What do you think?
  4. my belts was fixed by analogy with subaru imppreza, which have standard fixed position under seats. I want to fix it as you say, but i always used rear seats, because i use my car every day. About LOWER: i also like low cars, but i live here https://maps.google.com/maps?q=%D1%81%D1%8B%D0%BA%D1%82%D1%8B%D0%B2%D0%BA%D0%B0%D1%80&hl=ru&ie=UTF8&ll=53.748711,25.400391&spn=28.534159,79.013672&sll=37.0625,-95.677068&sspn=37.871902,79.013672&hnear=%D0%A1%D1%8B%D0%BA%D1%82%D1%8B%D0%B2%D0%BA%D0%B0%D1%80,+%D0%B3%D0%BE%D1%80%D0%BE%D0%B4+%D0%A1%D1%8B%D0%BA%D1%82%D1%8B%D0%B2%D0%
  5. Sorry for my english. I wont to listen your opinion about some changes of appearance and cabin. Maybe someone will give me a recommendation, how i can do my car better and beautiful. I know, that i should replace my rims. Any one idea? there you can see all night fotos there you can see fotos after renovation Some small parts of the interior now changed Thank you for your opinion
  6. i used VAG-COM: it show me error with pump. Then i replaced ABS unit with ABS pump - ABS dont work. Then i used VAG-COM and recode my ABS unit using code, which i take from my old ABS unit. Then ABS will work correctly Thaks for the help. Sorry for my english
  7. Hello, help advice, installed new brake pads, caliper guides. The symptoms are as follows: 1st Half pedal is very soft on the 2nd half begins to slow down, but if you go and abruptly stopped, the front wheels lock and the rear make a half turn and then only to be blocked. I flushed my brake system through many times at the institution machine, model of my car is golf MK3, with ABS, ABS is not working, the error pump. Maybe someone had similar symptoms? Due to the inability of the ABS or not? And with two on the brake pedal is normal. I paid for the unit abs and wait for his delivery because I
