Days Won
2
Everything posted by redborbet
check my post about the phenolic coilpack spacer !! heat is why they crack and vr6's run hot if you get a new coil pack i can supply you with a phenolic spacer that should safeguard your coil pack
updated add - second batch now available for some people that missed out on the first or didnt see the post , iv kept the origional add below Hi all i hope this is ok to post on here after owning my vr for 7 years and going through three coil packs i thought id adapt the same idea as my phenolic inlet manifold gasket to the coil pack to help protect it and prolong the life of it iv had the idea for a while and decided to get this sorted as there are non available to buy in the uk its a 6mm pacer cut plate with four new allen head bolts to fit directly to the car , it sits on the sid
Im running a v9f with a bosch valve as well Seems fine but i did do some reading and you can use the 007 or the forge splitter valve if you want more noise apparently I thing the bosch ones are ok up to 8psi and then anything over your best off upgrading
Messaged you mate if you havent recieved it my number is 07980690184 you can give me a text
Club Event: Rolling Road Day - 05/22/2016
redborbet replied to michael5556's topic in Meets & Events
A bacon buttie ? -
It was high for na , 230.2 was the figure the camber was out though and according to jon it can male a difference on the rollers but its been set up now and ran a few thousand miles just changed to fully synth oil to so it should all be performing at its max and hopefully good numbers i think anything over 200 is good na , iv put a fair amount in to get that figure like -
Hoping to hit 230 n/a again , daubt it though -
Sweet -
Ill be at this now mot passed today and a few issues sorted put me down for the rollers -
VW Festival Leeds 16/08/2015 Pictures (pic heavy)
redborbet replied to Dave_ciw's topic in Previous Events
Love the pics man -
Thank you daveboy
Exellent news i was really hoping id get on the stand cant wait for this now Should be a great weekend
Need to get signed up to the vr6oc but is there room for one more ? If so id deffo take the space as im camping all weekend so would be nice to get the rado on there after its full rebuild
VR6OC Competition Time DA POLISHER WITH POLISH & PADS
redborbet replied to Dave_ciw's topic in General Chat
Ill take five strips please can someone send me the paypal adress ? Id say next time you could make this process so much easier by just putting the paypal adress in the origional first post- 45 replies
- competition
- cleaning
(and 3 more)
Tagged with:
Upgrade 312mm Discs and Calipers Please Help !
redborbet replied to VR6DEN's topic in Wheels, Brakes, Suspension and Steering
Are the bleed nipples at the top or the bottom ? -
Mystery rear big brake conversion?
redborbet replied to bennyk's topic in Wheels, Brakes, Suspension and Steering
Not sure what kit it os but there rare on the ground i think , would you be a good sport and post up the part numbers for the disks and asociated parts -
Ina tappets ? Lifters help advice please
redborbet replied to redborbet's topic in Engine Maintenance and Problems
Will do mate im using a mk4 metal head gasket so the compression ratio is different , we have agreed at 150 very steady miles then ill travell the other 150 down to stealth for its map -
Cheers man , yea the schrick starts pulling at about 1500 to 4000 but then runs out of breath , hopefully with the cams coming in at 4 to thd limit and the big port throttle it should be ok , im only raising the limiter to a very safe point as i dont want to shag the valves up , just ordered the new ina tappets today so they will get submerged in oil for a few weeks before they get fitted -
Thanks for the info i did read that actually , i font think they will give a warremty unless you buy new tappets aswell ! As for the rev limiter its staying on so i can run standard springs and tappets as i read that upgraded springs cause a lot more wear on valvetrain , ill be runnng a schrick and big port throttle aswell so hopefully wont need to rev that high , ill be down at stealth next weekend so can always ask them then -
Thanks mate iv managed to get pages down to around 70 quid but im not sure if thats with or without stupid vat , im going to use new ones now iv decided as i really dont want to have to touch the engine again for a good fea years or more ! -
Also ill add that the cams are used with about 15,000 miles on them -
redborbet posted a topic in Engine Maintenance and Problems
Hi all I've got a rebuilt head minus lifters and I've also got a set of 268 cams going in , question is should I use new lifters or use the old ones . The lifters have done around 115,000 miles If I do need new lifters I'd like to use ina ones so where's the best / cheapest place to get them ? Ebay sell them for 76 quid for 12 Any advice apriciated -
Haha thats ace , i stuck my rocker cover through the house one ! And the chain covers and a few other bits , ideally you do not want to be running it with dishwasher salt
Also did the head but in silver but i cant post pics because tapatalks just spat its dummy out saying files are to big ! Elbow grease is king
Before Grotty as fuck ! Getting better And painted up
