DaveyB76
About DaveyB76
  • Birthday 06/19/1976
    Birmingham
  1. Could someone put me down for rolling road if there's still space available
  2. Could someone put me down for the rolling road if there's still room
  3. Found out the missing relays are for my air con lol so looks like I'm gonna need to buy a new fan or the fan module probably best to change them both to be on the safe side
  4. No got no fan to test with but I've stumbled across a box next to washer bottle and it looks like it should house 4 relays but mine are all missing :-(
  5. You have to unplug the black sensor from the thermostat housing then unplug the sensor on the rad and with the ignition on bridge out the red wire to the common wire that's stage 1 then bridge out the black and red wire with the common that's stage 2 which should run a little faster than stage 1 but mines not running at all on stage 2
  6. Just done a fan test and looks like stage 2 isn't working is this an easy fix if so how??
  7. Hi guys I was just wondering if my corrado Vr6 has a fault as its normal running temp is usually 110 degrees but it can creep up a little higher when in traffic just seems a little high to me and the fans are always over running when I turn engine off which makes me think there's a problem somewhere!!!
  8. Hi guys I've come across a P reg Mk3 VR6 that's on it's way to scrapers if no one buys it so I'm thinking about saving it as I know white is a rare colour but I haven't been to see it yet but the bloke says "The reason i am selling it is i drove it about 300 hundred yards and a knocking sound developed under the bonnet but only when the vehicle is under load and a bit when at tick over, its is also misfiring a bit and breathing a little bit heavy. The vehicle also needs water pump as its dripping 2 front wheel bearings as they are humming, i would say a set of front wings a new bumper and a
  9. Hi mate i've not long stripped out and put back together my dash and the ABS light switch had similar plugs going in to it??
